One thing I will say about the clocks.. .. .. they dont show up to brightly in the dark.. .. .. If you take the clocks apart you will find blue bulb covers inside that give off the blue subdued light .. .. .. fantastic to look at in the dark but not so hot in the failing light.
My thoughts are to remove the bulb covers and fit blue/orange/red tint sidelight bulbs, whichever colour looks best, given the bulbs are 30 bob each [or there abouts] they will have to wait untill a time when I'm feeling a little more frivolous.
As for fitting.. .. .. my original post states that they are a direct replacement for the original clocks.. .. .. needing only modification to the wiring.
Wiring them in is real easy [now I've done it] using the original clocks as a template I found which wire went where by following the copper tracing on the back.. .. .. .. then found the corresponding connection / copper track on the donor clocks.. .. ..
