V6 ESSEX INTO 96 S,W,B
Postby shirehorse » Tue Jul 15, 2008 12:39 am
HI ,,
im currently in the process of sourcing a essex v6 engine wich im hoping to drop in my 96 s,w,b , im assuming that if i remove the engine from an ambulance (with the box ) that it will pretty much drop right in without to much fabrication of engine mounts ect , also if i remove diesel tank and wash it out with petrol , it will serve its purpose ?? also would the radiator from the ambulance fit?? ive looked around on here for similar projects but cant seem to find any .. please let me kno if for some reason this project is not possible as im gonna rip the derv motor out and sell it to top up the funds for the v6 and i dont wanna end up scrapping me van ,,
if anybody can shed some light or give me any pointer,s ide be most greatfull .. cheeRS in advance , mike
loving life !!!
shirehorse
Re: V6 ESSEX INTO 96 S,W,B
Postby MrMPuk » Tue Jul 15, 2008 12:43 am
Gearbox will be totally different so you will need to make sure you get the gearbox cross member and propshaft, you will also need to cut the floor for the gearstick.
Postby shirehorse » Tue Jul 15, 2008 1:10 am
ah ok ,, that makes it a bit more tricky ,, im off to the scrappers tomozza where there is apparently a v6 bubble backed ambulance camper type transit hidden away in the corner ,, hopefully it will be complete and i will drag it out and bring it home ,, ive got a plazma cutter and a new welder so i should be able to make a good start .. cheeRS , MIKE ( GREAT WITH SPANNERS AND WELDERS!! HOPELESS WITH COMPUTER,S!) 8)
loving life !!!
shirehorse
Postby MrMPuk » Tue Jul 15, 2008 1:18 am
I have to ask, why is it you want to fit an Essex V6?
Postby shirehorse » Tue Jul 15, 2008 1:25 am
juss a bit of fun really ,, my old man used to have a fleet of ex riot vans and as a kid i loved the noise of a v6 !!
mainly its just for a laugh !! haha and of course that i want my van to go faster ,, :D
loving life !!!
shirehorse
Postby MrMPuk » Tue Jul 15, 2008 1:26 am
shirehorse wrote:haha and of course that i want my van to go faster ,, :D
So I have to ask then, why are you going for the Essex V6?
Postby shirehorse » Tue Jul 15, 2008 1:31 am
surely it will fly with v6 essex .. ive got carry nothing heavier than a pitbike or two and a few amps and stuff
i was under the impression it would transform my van in to a racer !! maybe im wrong but lets face it anything is faster than a standard tranny 2.5 di
loving life !!!
shirehorse
Postby shirehorse » Tue Jul 15, 2008 1:41 am
you see i have three transits ,, a semi high top s,w,b , wich i use for carrying all my work stuff (tools blocks slabs ladders ect ect ) i also have a twin wheel tipper wich i also use for work these two are fully laden at all times and are slow as your gran !!
im not really sure why i bought the one im planning to convert but i did and ive read a lott and learnt a lott from this forum and i juss thought ide have a bash at putting a v6 in ,, i thought ide go for the essex as it has no injection , i was also under the impression that it would sorta juss fit right in .. im paying my scally m8 to take my derv motor out tomozza so from then on in there,s no turning bk , lol ile probably regret it but when the engines out the pressure is on ,, ile keep you posted cheeRS
loving life !!!
shirehorse
Postby FredTransit » Tue Jul 15, 2008 6:27 pm
What's a bubble back ambulance? Do you mean a Mk2 van type? tb2 is selling an essex BTW.
FredTransit
Mk2 Trannyist
Postby Ratwood » Tue Jul 15, 2008 8:28 pm
where are you
Old transit's don't die I make trailers out of them
chris
Ratwood
Postby Luke » Tue Jul 15, 2008 8:32 pm
you should be ok :D - take as much as you can from the donor - complete engine mounts including the bits bolted to the chassis rails - same with the gearbox crossmember etc. - i'd also take the prop :D
the mk5 chassis rails are the same distance as the mk3 (what mk is the amby) but the mounts are different - the essesx box will only be a 4 speed - i wouldnt worry too much about the floor i'd just mod the hole position as you have the largest box tunnel with the mk5 so the earlier box will fit fine :D
you know there is 2 types of V6 essex and cologne (mine being a cologne 24v)
keep us updated sounds a good project 8)
oh and pics too :wink:
Postby Luke » Tue Jul 15, 2008 8:33 pm
and yes the rad from the donor will fit :D
Postby Ratwood » Tue Jul 15, 2008 11:22 pm
me and the wife fitted a essex v6 in a mk3 in 2 nights
this is the van
chris
Ratwood
Postby Ucof » Wed Jul 16, 2008 9:24 pm
I wish my Mk3 looked that good :(
Nice van! :D
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
