Problem after installing handsfree kit & reversing sensors
Postby hitnmisschris » Sat May 07, 2011 4:04 pm
This morning i finished putting in a wireless reversing sensor and a nokia bluetooth kit in my 04 lwb which i have had a month now.
All electrics were a doddle although i did blow the 15 amp reversing light fuse.
Replaced fuse with same rating - everything worked except van would not start!!
Not even a click from the solenoid on the starter motor.
Several attempts turning the key it started. Stopped and started it fine after.
Took it for a drive and it did the same thing.
Only connections i used was the igintion live for hands free along with a positive direct to battery, grounded it to a screw i drilled in.
Reversing sensor is powered by reversing light.
I am confident i have not disturbed anything but i am lost for ideas but on my last van you would hear solenoid on starter at least click when the starter was faulty
Any ideas gratefully received
Thanks, Chris
hitnmisschris
Re: Problem after installing handsfree kit & reversing senso
Postby blue estate » Sat May 07, 2011 4:14 pm
it's not shorting out some where causing battery drain ? or you've disturbed the pats ring
blue estate
Postby hitnmisschris » Sat May 07, 2011 5:42 pm
Dont think i have disturbed the pats ring on the ignition but i guess theres no harm in checking again. No battery drain as when it does decide to start its just as quick starting as normal.
hitnmisschris
Postby Dagenham Dustbin » Sat May 07, 2011 5:54 pm
Could it be that the wireless signal is blocking out the pats signal from the key??
Dagenham Dustbin
Postby hitnmisschris » Sat May 07, 2011 7:25 pm
Thats what i first thought but both the transmitter and receiver are only powered from the reverse light bulb - no separate supply to it.
Daft question could the blue tooth affect it as thats always on even though the same kit was in my previous smiley?
hitnmisschris
Postby ake » Sat May 07, 2011 7:39 pm
What's the pats light doing? Although I reckon your starter is going tits up
Postby Dagenham Dustbin » Sat May 07, 2011 8:25 pm
hitnmisschris wrote:Thats what i first thought but both the transmitter and receiver are only powered from the reverse light bulb - no separate supply to it.
Its not the power supply I was refering to, it the actual signal that is wirelessly transmitted.
I only thought this as my house had wireless cctv, but when the knob next door got BT broadband hub, the signal it transmits to his PC, wipes out my cctv. :x
Dagenham Dustbin
Postby hitnmisschris » Fri May 13, 2011 8:55 pm
Sorry for the delay in replying but i have been without internet all week and the van was fine until this evening and now it wont start!
Pats light does go out but not even a click from the solenoid can be heard - looking at the starter its a pig to get to compared to my old smiley.
Before i purchase a new starter in the morning is there any fuses inline with the solenoid or any thing else i should elimate before i skint myself?
Chris
hitnmisschris
Postby hitnmisschris » Fri May 13, 2011 9:39 pm
Just been back out to van armed with a torch and it struck up straight away!
Is it worth me replacing the starter relay as a basic elimination?
hitnmisschris
