Sat next to the old girl on the drive.
Plenty little mod's to follow I'm sure. First on the agenda is a roof rack and some additional led lighting for the rear.
And finally the key swapping ceremony
bezzabsa wrote:check the back of land rover owner etc, there is a company that does underbody coating that is guaranteed for life (i think)..they steam pressure wash then apply..
belly wrote:Pressure washer is fineGet some TFR and put it in a garden sprayer spray that all over the underside then get under there with a bucket and sponge, messy job but well worth it. Get some waxoyl to pump inside the chassis rails when it's all dry
Unfortunately if its a Southampton built van the protection isn't very good
You'll get used to the rackBut if you don't as I've mentioned I've got a full galv jobbie for a shr van that sits flush with the gutter rail it's also the type with same size outside box section as the Rhino, there not as pretty though
I've also painted some wooden batton and put them on my Rhino racks fixing them neatly with black cable ties, it dampens ladder/equipment/materials rattle and protects the rack at the same time although don't fit a batton to the first cross bar as the airflow causes the batton to vibrate and sound like a fart
Nice van btw
