03 MWB Recovery Build
Postby seanmcn » Sun Jan 05, 2014 12:22 am
I picked up this mk6 transit locally when I was looking for a recovery bodied transit, so I said I'd build one myself. The van needs a bit of work, rear brakes need attention, track rod need replacing and cut out some rust on the cab and a bit on the chassis.
Started by removing the dropside body
Lots of cleaning to be done on the chassis and a respray.
seanmcn
Re: 03 MWB Recovery Build
Postby dannyboysean » Sun Jan 05, 2014 1:47 am
making a good start there fella
dannyboysean
Postby seanmcn » Tue Jan 07, 2014 9:45 pm
Removed the rear light panel and towbar.
Found plenty of rust behind expanding foam and body filler!!
A bit behind the cab...
I reckon there is more filler here!
seanmcn
Postby dannyboysean » Tue Jan 07, 2014 10:10 pm
county Meath reg is that....good progress mate
dannyboysean
Postby seanmcn » Tue Jan 07, 2014 10:16 pm
Yeah it is.. was originally northern.
seanmcn
Postby dannyboysean » Tue Jan 07, 2014 10:27 pm
seanmcn wrote:Yeah it is.. was originally northern.
where are you from fella?
dannyboysean
Postby Guy88 » Tue Jan 07, 2014 10:29 pm
while your there, re enforce the chassis behind the cab :wink:
there starting to break in half like the old MK3's
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby seanmcn » Tue Jan 07, 2014 11:11 pm
Waterford
Guy88 wrote:while your there, re enforce the chassis behind the cab :wink:
Yeah I might as well! Any links to do it right?
seanmcn
Postby Guy88 » Tue Jan 07, 2014 11:15 pm
last one i saw they cut holes in the cab wall and put box section front to rear on top of the chassis in a mk5 style, then plated both sides of the rails
the box section believe was part of the bed subframe and went about 18" under the seats in the cab,
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby seanmcn » Tue Jan 07, 2014 11:27 pm
Ok I think I get ya.. There is more rust in the cab behind the seats. I'll get pic's tomorrow.
seanmcn
Postby seanmcn » Wed Jan 08, 2014 12:52 pm
Steel came
seanmcn
Postby dannyboysean » Wed Jan 08, 2014 1:18 pm
Its all go now mate
dannyboysean
Postby seanmcn » Wed Jan 08, 2014 5:22 pm
Plates for the base
seanmcn
Postby seanmcn » Wed Jan 08, 2014 7:25 pm
The first of many holes to be welded
seanmcn
Postby Frank190 » Wed Jan 08, 2014 7:40 pm
A lot of work being put into this - fair play. Watching for updates :)
Frank190
