a new project swb auto rare van
Postby Richieintransit » Thu Feb 13, 2014 10:14 pm
Hi guys i just wrote a massive story on this, hit send and it timed out and I lost the lot,,, :x so here is a brief one!
rare little van, swb 150! sht auto with a/c e/w c/l e/m and the worlds most annoying remote locking alarm, (free to collector as long as you can remove without mucking my van up as i can't use these)
anyway here are some pics
is this more powerful than my p reg? engine definately different, this is a very late 1998
any ideas why my heater has no fan?
thanks guys
I love automatic transits,,, well not the mk 6 durashit
Richieintransit
Re: a new project swb auto rare van
Postby transitandy » Thu Feb 13, 2014 11:32 pm
AH thats you who done a deal off ebay then m8y :lol: :wink:
Postby Richieintransit » Thu Feb 13, 2014 11:35 pm
yer hope i didn't upset anyone but you all know how much i need auto so had to get it even though it was up north!! (30 odd miles but I hate going far and even that seemed a long way and took hours!)
Richieintransit
Postby transitandy » Thu Feb 13, 2014 11:40 pm
I was watching it as i thought it desirable :)
Well done you as it looks a great van :)
Postby Richieintransit » Fri Feb 14, 2014 12:05 am
transitandy wrote:I was watching it as i thought it desirable :)
its ok,,, not as good as the ad looked, needs lots of tlc, inside is untidy, few funny noises I'm hoping are not gearbox or diff, no heater and don't think the resistor is the reason as per ad!, all arches are pretty naff, rear inner arch has holes, found a hole in chassis needs a few bits of welding etc, but I think it's still worth a grand as it's a rare little van, don't see many swb 6 studs! I think it would have gone for more on ebay but I don't think the buyer would have taken it unless they were deaf and partially sighted!! the noise was a good bargaining tool as most people would have walked away, but as I'd travelled 20 miles out of my comfort zone I had to buy it!!!
Richieintransit
Postby transitandy » Fri Feb 14, 2014 12:18 am
He did not say all that on the add :roll:
Oh well your the best man for the job m8y
Postby Richieintransit » Fri Feb 14, 2014 12:38 am
transitandy wrote:He did not say all that on the add :roll:
lol they never do on ebay mate that's why i have to look first,I recon from the way it was described it would have hade 1500 or more, I've had so many wasted journeys, only a few weeks ago i bought a sprinter recovery truck up north (well for me anywhere is up north) for mega money, only to find on the drive home many undescribed issues,, and this was a 6 year old truck! which is why i've cut my losses on that and now back with transits! I would ideally like a transit recovery in auto but never ever seen one that was any good, only auto i ever found was in scotland and gearbox was naff so couldn't get it home!
Richieintransit
Postby MinorMatt » Fri Feb 14, 2014 3:23 pm
Guess what I got from Harris's yard last week Richie...
The 2 bits of trim you are missing from the side :lol: Picked them up because they are the ones that go missing and may be useful to someone!
ALL mk5 automatics are the 85PS turbo. If the fan doesn't work, either the blower motor is knackered or the switch is burnt out!
As you know axle whine is common!
Postby Richieintransit » Fri Feb 14, 2014 3:54 pm
oww can i buy them ? how much?
I didn't know that axle whine was common, i'm not sure it's axle whine anyway that's why I could do with your ears on it!!
why does this engine look different?
do you have the switches in your parts catalogue! need the one with air con,
also do you have the filler surround and cap as mine is missing cap and surround is broke, are they easy to change?
cheers matt
Richieintransit
Postby MinorMatt » Fri Feb 14, 2014 4:47 pm
I might have a spare cap, I don't have a spare surround and I definately don't have an aircon switch - but they are meant to be the same as mk1/2 mondeo ones.
You could still get the surrounds from ford 9 months ago for about £15. Undo screw below filler neck, prise the old surround out (it will break) push the new one in and do the screw up.
I will come and have a look at it if you want - but only when the weather is better!
Matt
Postby Richieintransit » Sat Feb 15, 2014 1:00 am
MinorMatt wrote:I might have a spare cap, I don't have a spare surround and I definately don't have an aircon switch - but they are meant to be the same as mk1/2 mondeo ones.
Matt
yes please matt, what's wrong with the weather?!
Richieintransit
Postby Richieintransit » Sat Feb 15, 2014 1:06 am
all heater wires and plug look good how does the plug come out to check for power? and which wire goes to the fan so i can test it's working by feeding it??
thanks guys
Richieintransit
Postby soprano1982 » Sun Feb 16, 2014 2:14 am
Top buy :D
soprano1982
Postby MinorMatt » Sun Feb 16, 2014 12:32 pm
The heater switch is a pain to remove. The first thing I do is check the fuse (30A) then remove the radio & its surround, take the plug out of the motor ans check if the voltage is there (switch in position 3). If there is, the motor is normally dead, if there are no volts its the switch.
Postby Richieintransit » Sun Feb 16, 2014 1:47 pm
MinorMatt wrote:The heater switch is a pain to remove. The first thing I do is check the fuse (30A) then remove the radio & its surround, take the plug out of the motor ans check if the voltage is there (switch in position 3). If there is, the motor is normally dead, if there are no volts its the switch.
it's a nice day matt!!! have you ever tried getting a size 9 through a stereo hole!!!
Richieintransit
