We were originally looking for a SWB low roof that would fit under the 2 metre barrier at the local tip, then we found out that the tax & insurance is no more expensive for a LWB semi high roof, so thats what we went for. I'll use the car if I need to go to the tip.
The higher roof should save me a few bangs to the head....hopefully.
[url]
/url]See the Hijet scowling in the background?
[url]
/url]Two tone paintjob, pure class.
[url]
/url]The door bottoms are made of metal, not filler.
I'ts been a work van, so it's filthy inside. But we will clean it thoroughly & check everything is working as it should, before we use it.
This isn't a problem as the Hijet still has tax, MOT & insurance until the end of May. So we'll carry on using that until the Transit is ready.
Things that need doing....
Fuel pump has a slight leak.
Needs a full service.
Speedo not working.
Hazard lights only work on LHS.
Number plate lights not working.
Door key is very worn & won't open drivers door.
Also a couple of times yesterday, I turned the ignition key & nothing (no ignition lights or anything). Then I pulled the bonnet release & everything came back on. I assume it's a bad earth, so I'll check the wiring.
I'm sure the list will grow & I will be pestering you all constantly for answers & solutions to my problems.
But I'm quite pleased with the van.....at the moment.
/url]
/url]
