Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby madbri » Mon Jul 30, 2012 8:13 pm
8) 8) 8) 8) well done sir luke :mrgreen:
madbri
Postby AlanN » Tue Jul 31, 2012 8:13 am
Nice one, look forward to seeing your vid too 8)
Postby robbie.cee » Tue Jul 31, 2012 2:43 pm
AlanN wrote:Nice one, look forward to seeing your vid too 8)
x 2 8) 8)
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby transitandy » Wed Aug 01, 2012 8:21 pm
x 2 8) 8)
x3 8) 8)
Postby MattBlackMinibus » Wed Aug 01, 2012 8:24 pm
Congratulations on passing your MOT :!: :!: 8) 8)
And double swivelling seat sounds cool as mate, nice one :D
Starting All Over Again
MattBlackMinibus
Postby Luke » Wed Aug 01, 2012 11:52 pm
cheers - now taxed too 8) 8)
i was driving it and was having a play with the gears - it always seemed slow to set off in drive (hence north weald) - i tried it manually selecting 1st and seemed to be loads faster 8) - ive been doing a bit of research and i'm pritty sure its something to do with the electronics/wiring :|
Postby AndyG » Thu Aug 02, 2012 1:24 pm
It might be a feature (like some other boxes) that it pulls away in 2nd, unless kickdown is engaged or manually selecting 1st :idea:
Postby Luke » Thu Aug 02, 2012 4:28 pm
AndyG wrote:It might be a feature (like some other boxes) that it pulls away in 2nd, unless kickdown is engaged or manually selecting 1st :idea:
i hope thats the case andy :D
Postby madbri » Thu Aug 02, 2012 6:04 pm
how do ure gears work? ie could it b a faulty solinoid?
madbri
Postby Luke » Thu Aug 02, 2012 11:25 pm
wired up the kick down and i think andy is right :!: i reckon at north weald i was setting off in 2nd :roll: it does seem a fair bit faster now 8) hopefully i can get it on the 0-60 sprint at ford fair for a proper test :mrgreen:
i had to mount a new switch for the kickdown as the toyota one wouldnt fit the transit pedal but i ran out of gas - so the mount is tacked on temperarly :| (hence no photos :lol: )
i really want the rev counter working now and also need to sort the bypass on the turbo vents directly out with no silencer - its way too loud :roll: :lol:
Postby Luke » Sat Aug 04, 2012 7:56 pm
update :!: still not right :roll: pritty sure the problem is wiring related re. the autobox - i think its the 'lock up solenoid' you can be travelling at 50mph boot it the box kicks down the engine revs up but there's little increase in speed :?
can't wait to get this sorted :twisted: :lol:
Postby Luke » Sun Aug 05, 2012 10:49 am
well i'm not so sure it's electrical now :( it might be the actual box slipping :( i have got a spare box i could swap over but i need to be quick to get it done before fordfair :|
Postby robbie.cee » Sun Aug 05, 2012 10:51 am
hows that vid on seat rotatory base doing m8? or a pix at least pls pls pls 8)
Had
MAKE IT FIT
robbie.cee
Postby Luke » Sun Aug 05, 2012 10:55 am
robbie.cee wrote:hows that vid on seat rotatory base doing m8? or a pix at least pls pls pls 8)
sorry robbie clean forgot - ive been too busy scratching my head with this 'being slower than before' problem :lol:
anyway you'll see it at FF but i'll post it up for others :mrgreen:
Postby robbie.cee » Sun Aug 05, 2012 12:59 pm
ill be at the Mania dude, hoping to get there early fri- gazeebo in van if needed!
Had
MAKE IT FIT
robbie.cee
