Once weather cools down. I'll crack on & get mk7 rear axle fitted
mrepson wrote:epic work,will be a mint van when finished
johnsonmy wrote:Paul, as someone with much Transit and Connect experience, I have two questions. 1) It looks like your current Transit has both headlight beams lit when main beam is on. Is this correct? 2) Will the turn signal/beam switch fit a 2011 Connect? Thanks, and really like your work.
johnsonmy wrote:Thanks for the clarification Paul!
loot wrote:Now you don't get that kind of service in the garage Paul![]()
Did you have to guy them from Ford?
Brains_transit wrote:I'm led to believe the ignition barrel is different on a mk7 looking at eBay but the column must be the same fixings
Users browsing this forum: BROWNYS V6
