My mk5 smiley V6 Jag engined van
Re: My mk5 smiley V6 Jag engined van
Postby robbie.cee » Wed Mar 09, 2016 10:42 am
Reckon mondeo v6 ecu would run that at a push if firing order same as jag!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed Mar 09, 2016 8:58 pm
Might be abke to use the mondeo v6 dash cluster at any rate!
Postby robbie.cee » Wed Mar 09, 2016 11:05 pm
Could simplify things a bit using ford ecu but would it loose power over the jag ecu s ?
Had
MAKE IT FIT
robbie.cee
Postby Pocketrocket » Wed Mar 09, 2016 11:40 pm
MinorMatt wrote:Might be abke to use the mondeo v6 dash cluster at any rate!
Yeh thats the plan, keeping an eye on ebay for a good priced v6 cluster
robbie.cee wrote:Could simplify things a bit using ford ecu but would it loose power over the jag ecu s ?
Yeh after much debating between me and luke im probably going to go down the megasquirt road, with reguards to ecu. The jag management is just to far integrated into everything, ms should be a nice simple install and will still be able to keep the vvt, only thing I'll have to change is the throttle body from elec to manual.
With some tubular manifolds and stainless system further down the road and a proper set up on a rolling road it should see 250+ bhp
1991 mk3 2.5di county 4x4 lwb ex mini bus camper conversion
1999 mk5 tourneo (previously jagvan, now Vw PD powered now with new owner :cry: )
2000 mk5 with a jaguar twist :wink: (now dead but will live on)
1996 disco 300tdi 1.2 offroad toy :D
Pocketrocket
Postby Pocketrocket » Wed Mar 09, 2016 11:44 pm
Has been raining most of the day up here and all the interior from the jag is stored in the van for the time being so not wanting to get wet (and not wanting to be arsed too!) I made a start on the rear seats/frame :)
Pocketrocket
Postby robbie.cee » Fri Mar 11, 2016 8:56 pm
Bit of fettling may be able to make the leccy throttle open by cable if the actuator can be removed to leave a shaft you can put a quadrant on and cable to pedal... just a thought
Had
MAKE IT FIT
robbie.cee
Postby DodgeRover » Fri Mar 11, 2016 10:27 pm
What about a pre pats ESC ECU from a mondeo V6, vvt is apparently just a live feed at the correct rpm so you could probably creatively bodge that, you could keep the all the injection gear that way, not sure if the mondeo ECU is hack able?
DodgeRover
Postby robbie.cee » Fri Mar 11, 2016 11:00 pm
Even eec v can have pats deleted and auto box deleted from pcm.... at least as you say could botch a trigger for vvt like a switch on pedal like a kickdown switch or rpm window switch or even a shift light to trigger it!
Had
MAKE IT FIT
robbie.cee
Postby Pocketrocket » Sat Mar 12, 2016 10:49 am
robbie.cee wrote:Bit of fettling may be able to make the leccy throttle open by cable if the actuator can be removed to leave a shaft you can put a quadrant on and cable to pedal... just a thought
I was actually thinking of that the other day! The motor/actuator is quite big that drives the tb and the tps os on the opposite side, I'll have to look into it more ;)
DodgeRover wrote:What about a pre pats ESC ECU from a mondeo V6, vvt is apparently just a live feed at the correct rpm so you could probably creatively bodge that, you could keep the all the injection gear that way, not sure if the mondeo ECU is hack able?
Its not as daft as it sounds, its basically the same engine so should have the same firing order etc as the ford duratec, im not sure of the pats etc but yes the vvt is just an on/off signal at a given rpm so with megasquirt its just a programed output at whatever rpm you like
robbie.cee wrote:Even eec v can have pats deleted and auto box deleted from pcm.... at least as you say could botch a trigger for vvt like a switch on pedal like a kickdown switch or rpm window switch or even a shift light to trigger it!
Tis a thought, the reson im looking into ms is the tunability, way way way down the line I was thinking low boost turbos, but thats just an idea atm, pedal switch isn't a bad idea though ;)
Pocketrocket
Postby robbie.cee » Sat Mar 12, 2016 1:29 pm
Gonna be one badass fast van when its done....
The closest to the transit xj220 on our forum lol
Had
MAKE IT FIT
robbie.cee
Postby Pocketrocket » Sun Mar 13, 2016 3:40 pm
robbie.cee wrote:Gonna be one badass fast van when its done....
The to the transit xj220 on our forum lol
Not so much bothered about it being ridiculously fast just so its got plenty enough to surprise people every now and then :lol:
The main aim is to make it just a realy nice van to drive and be in, hopfully be a nice finnish when I've done :)
Pocketrocket
Postby robbie.cee » Sun Mar 13, 2016 5:05 pm
I'm sure it'll be awesome once done!
Had
MAKE IT FIT
robbie.cee
Postby Pocketrocket » Mon Mar 14, 2016 8:53 pm
Bit done on the van tonight..........YES THE VAN! :lol:
Started pulling out interior trims/boards out the back ready for cutting/welding, she needs a bit more tlc than first thought but nothing thats gonna give me any trouble, no pics as yet will het a few next time.
On another note, picked up a divers side seat frame to fit in the passenger side for a single seat and won these on ebay, 1just needs a sand blast and the others a light refurb and re drilling.........happy days! :D
Pocketrocket
Postby spudmab » Tue Mar 15, 2016 2:24 pm
This is gonna be a fun toy when it's done, I keep thinking about making a silly fast van, can't wait to see more progress. Good luck with the welding hope there isn't to much
spudmab
Postby Pocketrocket » Sat Mar 19, 2016 8:03 pm
Few pics from last night, seats and floor matt out, started to trim out some rust on the passenger side wheel arch, started drilling out spot welds on the wing but will just chop it out when it comes to it, im now wandering tho if im gonna make north weald due to the extra work but i'll give it a shot! :wink:
Picked up the wheels today so at least thats a step in the right direction! :lol:
Pocketrocket
