Red Ven
Re: Red Ven
Postby dumper » Mon Mar 01, 2021 8:25 pm
Yes done that many times when vosa back then had teat centres you would see in nearly lay byes nearby a fitter in a boiler suit laid underneath wiping it all down before going in for a test .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Red Ven
Postby Nordic Blue » Tue Mar 02, 2021 11:40 am
Wow - congratulations!
Looking forward to following the next stages of your work!
2009 Renault Trafic Sport Crew Cab
Vans I have also owned:
1982 MK 2 SWB Transit
1992 Fiat Ducato
1993 MK 4 SWB Transit
2005 MK 6 SWB T280 Transit
Nordic Blue
Re: Red Ven
Postby DG-Unit » Tue Mar 02, 2021 11:49 am
Nordic Blue wrote:Wow - congratulations!
Thanks Nordic Blue. It’s been emotional :lol:
Now trying to get to the bottom of the new knocking noise that decided to show itself on the way to the MOT. Contenders so far include CV joint, PAS pump and the new tie rod ends. Put a video of the noise at the end of the Sound Diagnosis thread I started if anyone fancies a listen https://fordtransit.org/forum/viewtopic.php?f=2&t=201432
2004 Transit SWB 85 T260
DG-Unit
Re: Red Ven
Postby dumper » Tue Mar 02, 2021 11:57 am
I’ve had a knocking coming from inside the struts/ shock absorbers before used to change loads on Astra vans and my mk6 with genuine Ford ones did it from not a lot of miles when they came out of warranty they had no play in them and went through mot loads of time it was just annoying.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Red Ven
Postby DG-Unit » Tue Mar 02, 2021 12:29 pm
dumper wrote:I’ve had a knocking coming from inside the struts/ shock absorbers before used to change loads on Astra vans and my mk6 with genuine Ford ones did it from not a lot of miles when they came out of warranty they had no play in them and went through mot loads of time it was just annoying.
That’s a new one to add but possible with all the hitting of a lump hammer they’ve had - changing ball joints and the tie rod ends. Any way of telling it apart from other possible causes?
DG-Unit
Re: Red Ven
Postby dumper » Tue Mar 02, 2021 1:36 pm
If you have knocking when you rock the steering when stood then I’d be looking at steering/ ball joints but if it’s when driving in a straight line and it’s coming from potholes then maybe in the leg or the rubber top mount maybe from the advisory from wheel bearing if same side .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Red Ven
Postby DG-Unit » Tue Mar 02, 2021 5:26 pm
dumper wrote:If you have knocking when you rock the steering when stood then I’d be looking at steering/ ball joints but if it’s when driving in a straight line and it’s coming from potholes then maybe in the leg or the rubber top mount maybe from the advisory from wheel bearing if same side .
No knocking in steering when stationary and no knocking caused by potholes, speed bumps, curbs or electric scooters. It’s had recent ball joins, drop links and control arms & bushes.
Seemed unlikely but i’m more and more thinking it could be the CV joint but puzzled because the gaitor isn’t broken and it didn’t make ANY noise before being stood still for 2 months. But now it does as soon as it’s moved? Who knows. Might find some expanding foam and newspaper inside the joint the way this van has been. Only other culprit I can think of is the PAS pump but i haven’t had that or a CV joint go on me before so I don’t know what they sound like.
DG-Unit
Re: Red Ven
Postby dumper » Tue Mar 02, 2021 8:57 pm
You tend to hear cv joints click when turning slow in lock .if you bounce the front surspention can you make it knock what makes me think of the strut is on mot they didn’t find anything.My brothers Doblo had slight play in n/s/ bearing and he had a knock had new bearings and he thinks it’s gone .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Red Ven
Postby ned » Tue Mar 02, 2021 9:43 pm
My PAS pump is on its way out, you’ll know when they go as the steering becomes very notchy and sounds like there’s a chaffinch in the engine.
CV tend to clunk on turning as dumper said.
The knocking could be the strut top plates or the bearing with play in it, have you checked the hub nut is tight?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Red Ven
Postby DG-Unit » Tue Mar 02, 2021 9:55 pm
ned wrote:My PAS pump is on its way out, you’ll know when they go as the steering becomes very notchy and sounds like there’s a chaffinch in the engine.
Checking the hub nut is a good shout anyway so I’ll do that tomorrow. Just going to Google what a chaffinch sounds like :lol: Interestingly just check the MOT sheet and bearing play isn’t on there so I don’t know. I can get the front on stand and check for bearing play. While I’m at it is there any safe way to check/replicate the click of a CV gone? It’s just really strange it’s suddenly happened after months of nothing and no problems before. All I’ve done in that area is have it jacked up on the subframe for welding access, replacing the tie rod ends and changing the ABS sensor I clipped with an angle grinder.
DG-Unit
Re: Red Ven
Postby dumper » Tue Mar 02, 2021 10:29 pm
Just drive it in a circle in both locks the more lock you put on the more it should click .
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Red Ven
Postby DG-Unit » Tue Mar 02, 2021 11:26 pm
dumper wrote:Just drive it in a circle in both locks the more lock you put on the more it should click .
Sounds like CV joints then. Clicks always when taking a left or right turn at slow speed and when moving off from the lights. Have to be super slow and gentle for it not to click so much. Here’s the link to the video of the noise it’s making in case anyone can’t find it in the other thread: https://youtu.be/-2ywonblfEE. Would be good for a few more confirmations before I shed out on new driveshafts.
DG-Unit
Re: Red Ve
Postby dumper » Wed Mar 03, 2021 1:05 am
You should be able to get outer cv joints and not a full shaft it’s not often that the inner one goes unless the boot has been split for a long time and lost all the grease.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Re: Red Ven
Postby ned » Wed Mar 03, 2021 10:11 am
Outer cvs are about £50 iirc, I have a new one to go on the n/s but as usually I’m procrastinating on doing the relatively easy job.
Not listened to the video yet but what you describe sounds similar to mine, clicking on turning and clunking when pulling off from a stand still.
ned
Re: Red Ven
Postby DG-Unit » Wed Mar 03, 2021 10:49 am
ned wrote:Outer cvs are about £50 iirc, I have a new one to go on the n/s but as usually I’m procrastinating on doing the relatively easy job.
I'm seeing whole driveshafts for £50-80 each and I've already got some new gearbox oil seals and intermediate bearing clamp so will probably go down that route unless someone tells me it's too much hassle popping them out of the diff.
DG-Unit
