All About FLER
Re: All About FLER
Postby MinorMatt » Tue Aug 04, 2009 10:39 pm
wont be finished :shock:
Might be legal though, thats about the best I can hope for :lol:
Re: All About FLER
Postby Nadjenka » Wed Aug 05, 2009 7:31 am
:shock: :shock: :shock: That is quite a bit of rust there! Is that the worst side? Doing a good job, I wish I had enough courage back then to cut the arch the way you're doing it... :roll:
Nadjenka
Re: All About FLER
Postby MinorMatt » Wed Aug 05, 2009 4:02 pm
The other side is worse (round the arch at least) at the back but better at the front...
Having said that there doesnt appear to be as much filler in the bit between the arch and the next panel
Nipped into a local breakers today and they wanted £150+vat for a cylinder head :shock: and that was using my own labour to remove it :shock: :shock:
Re: All About FLER
Postby MattBlackMinibus » Wed Aug 05, 2009 5:36 pm
MinorMatt wrote:Nipped into a local breakers today and they wanted £150+vat for a cylinder head :shock: and that was using my own labour to remove it :shock: :shock:
:shock: Bloomin Nora :shock: Bar stewards :!:
Starting All Over Again
MattBlackMinibus
Re: All About FLER
Postby supersport » Wed Aug 05, 2009 9:49 pm
if you need a hand i might be able to lend one (or two).
where about's in southampton are you?
servicing from £75, pm me.
supersport
Re: All About FLER
Postby MinorMatt » Wed Aug 05, 2009 9:57 pm
Hi mate
Im not really in Soton im more fareham way!
This project has officially stalled. I now have literally no spare time to work on the van until after transitmania :(
Re: All About FLER
Postby MattBlackMinibus » Thu Aug 06, 2009 10:24 pm
Same here Matt :!:
I'll have all the time in the world after this month,
but NONE in the next few weeks :evil:
Typical ain't it :roll:
MattBlackMinibus
Re: All About FLER
Postby MinorMatt » Thu Aug 06, 2009 10:41 pm
but at least yours is legal :?: :!:
Re: All About FLER
Postby MinorMatt » Mon Aug 31, 2009 6:07 pm
Okay... following a parts exchange at transitmania... (Thanks Andy and Altransit :D )
FLER lives :) Engine runs :D The only thing is that the exhaust blows, the little pipe from the top of the thermostat leaks and the stat housing needs a new gasket :) Nothing major there.
I turned up what I believed to be the fuelling screw, but it sent the idle right up so I put it back again! I guess that is the fuelling screw, and then you adjust the idle back to normal somewhere else? (The cable itself??)
But all in all I am pretty happy. I can move my van again!
Re: All About FLER
Postby Guy88 » Mon Aug 31, 2009 6:46 pm
wind the ine on the back facing forwards in then drop the tickover on the throttle stop, then adjust mid range for smoke
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: All About FLER
Postby MinorMatt » Mon Aug 31, 2009 6:49 pm
Cheers mate :)
Re: All About FLER
Postby AlanN » Mon Aug 31, 2009 10:16 pm
Right, were back from Transitmania Matt, lets see some more :D
Re: All About FLER
Postby MinorMatt » Mon Aug 31, 2009 10:18 pm
Working on it as fast as I can Alan...
All I could add at the moment is a picture of a turbo engine with a bosch pump on it!
Re: All About FLER
Postby Altransit » Mon Aug 31, 2009 10:18 pm
AlanN wrote:Right, were back from Transitmania Matt, lets see some more :D
He's had all day, ..................... and nothing :roll:
:lol: :lol: :lol:
Re: All About FLER
Postby AlanN » Mon Aug 31, 2009 10:24 pm
:lol: :lol: :lol:
:lol: :lol: :lol:
