MK6 SWB Cosworth YB Conversion!
Re: MK6 SWB Cosworth YB Conversion!
Postby WENNY » Fri Apr 25, 2008 9:58 am
rev counter wire is green
1st temp sensor woth 1 wire is for gauge on clocks, wire colour is brown with a white stripe
2nd temp sensor is cold start etc for ecu usually blue plug, wire colours are black wire with green stripe and brown with green stripe
350 200PS 3.2 LIMITED LWB
350t 125 RWD MARTINI TRANSIT
WENNY
Postby Luke » Fri Apr 25, 2008 9:45 pm
WENNY wrote:rev counter wire is green
must be different on this one cant find any of those wires :(
Postby Luke » Fri Apr 25, 2008 9:49 pm
bit more done today
removed a load of LPG wiring, general tidying up done, mounted the wiring bracket and fitted the clutch :D
oh also welded the end of a mk4 transit pedal to the mk6 pedal allowing the sierra cable to be used :D needs a bit of adjusting as its only getting 3/4 throttle :( i'll sort it after north weald - got to give my van a chance :wink: :lol: :lol:
edit- wired in the altenator too :D
jobs left
sort out fuel pipes - at the moment they go round the front of the engine bay
fit intercooler - gonna use the standard cossy one temp untill a custom one is made
finish off wireng (needs a lot of tidying up)
have a new pas pump hose made up to fit cossy pas pump
adapt starter so its held by more than 1 bolt
get exhaust made - planning on a full stainless system
refit front panels
Postby Luke » Sat Apr 26, 2008 8:42 pm
good day today
Actually drove it today 8) 8) 8) 8) 8)
fitted new copper fuel pipes :D
made a temprary hose for the pas so we could run it, and tidy'd up the wiring - still got a fair bit to do tho does anyone have a wiring diagram for the DOHC :?: - theres a lot of wires im not sure what they are for :|
changed plans on the intercooler - gonna use a transit one now :)
also won some mondeo clocks on ebayhttp://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0244703090
but its all on schedule to be finished for next weekend 8)
jobs left
fit intercooler - gonna use the standard transit one temp untill a custom one is made
refit front panels
Postby Guy88 » Sat Apr 26, 2008 8:43 pm
you need a TIS disc mate :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby madmark » Sat Apr 26, 2008 9:38 pm
:shock: i take it you took it easy when out on your test drive! :wink:
Postby Luke » Sat Apr 26, 2008 9:47 pm
madmark wrote::shock: i take it you took it easy when out on your test drive! :wink:
yeah turbos not connected yet so a nice steady drive :lol:
Postby mantav8 » Sat Apr 26, 2008 10:23 pm
Well done bud!-I was gonna' suggest a Transit I/C but didn't want a slating! LOL!
Just thrown 2 brand new ones away! :roll:
Keep at it! :mrgreen:
mantav8
Cosworth Powered
Cosworth Powered
Postby Luke » Sat Apr 26, 2008 10:39 pm
mantav8 wrote:Just thrown 2 brand new ones away! :roll:
what transit ones :?: :shock:
Postby Luke » Mon Apr 28, 2008 10:03 pm
Today
change of plan on the intercooler - couldn't get a transit one cheep enough so fitted the sierra one :D the theory was it's only gonna be temprary till a custom one is fitted so the cost of a transit one might aswell go towards a custom one :D
just need to sort out the pipework now :D
also mounted the coil and did a bit more on tidying the wiring :)
other developments - it's booked in for a full stainless system this week 8)
Postby Guy88 » Mon Apr 28, 2008 10:07 pm
the sierra one i got dont look far off a transit one mines off a 2WD thou
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Apr 28, 2008 10:37 pm
Guy88 wrote:the sierra one i got dont look far off a transit one mines off a 2WD thou
its not far off size wise but the hoses angle slightly differently :D
also forgot to mention we fitted the fan cowl off the petrol rad - just upside down - all it needed was a it cutting off that was in the way of the hose and clamping on 4 bolts and washers did the trick :lol: we'll replace it one day with a pukka fwd one :D
i'm intending wiring the fans on a switch for north weald as we've not got a sender in the pipework yet - something to sort out later :D
Postby Luke » Tue Apr 29, 2008 11:55 pm
todays progress
getting close now :mrgreen: actually bolting bits on for good - wings front panel etc are all on now :D wiring is tidy enough for now - not gonna short out - the full loom needs taping up and there's still a lot to cut out but i dont want to cut anything out im not sure we'll need so i'll get it road tested 1st :D
measured up for all the intercooler pipes and stu's getting them tomorrow - also a new pas hose so make a neat job of cosworth pump to transit rack :)
had a problem getting the servo to work - we tried a larger bore hose (8mm) and it seemed better but it really needs a road test :?
still waiting for the mondeo clocks for the temp gauge - should be here wed or thursday :)
spoke to the guy who's doing the exhaust today - he was supposed to ring us back to see if we could take the van up tomorrow but he didn't - so we'll give him a ring tomorrow :?
Postby griffj » Wed Apr 30, 2008 7:41 am
youve made some amazing progress with this conversion, cant wait too see it finished, yourself and stu are seriously talented.
just promise me one thing,
when its done and you can nail it down the strip, we can all see it on you tube!! :D
griffj
Postby Luke » Wed Apr 30, 2008 2:33 pm
oh yes 8) we'll make sure we get plenty of video clips of all the vans on the strip* 8)
The 1st guy who was doing us the exhaust didn't ring back again today :( - 2 days in a row so you snooze you loose :lol: can't risk it being sat there waiting for bits etc. so it's now booked in to http://www.exhaustsuk.com in sheffield this friday 8)
so today we dont really have any work to do on it :(
waiting for :arrow:
dash/temp gauge - in post
pas pipe - being made now
intercooler pipes - due in tomorrow
the only jobs to do are :arrow:
the fans need wiring up - i was thinking of just fitting a switch on the coil side of the existing relay (where ever it is????) and using the wires allready there :D
The starter still needs modding - but its not gonna stop us getting there :lol:
*excuse no.1 - this van (and mine) are both standard and havent had ANY tuning done yet so if we get wasted by nitroman's diesel thats why :lol: - and we'll be back next year with a few more HP :lol:
