Mk5 slow progress report
Re: Mk5 slow progress report
Postby dirtydog » Wed Sep 24, 2014 8:17 am
Thanks Resto, I found a tin of white Hammerite in the garage so going to use that as I've already got it as I'm on a budget this month and need a couple of new tyres as well
dirtydog
Postby dirtydog » Thu Sep 25, 2014 2:02 am
And painted
2 coats of Hammerite
New front tyres going on tomorrow
dirtydog
Postby RustWidow » Thu Sep 25, 2014 6:54 am
Well done dirty, you're doing well
RustWidow
Postby dirtydog » Thu Sep 25, 2014 6:54 pm
We'll today was spent getting a couple of new tyres and continuing with the floor, first job was scrub the floor mat because it was filthy!
Whilst that was drying I gave the cab a quick Hoover out and then it was time for some sound deadening stuff to go down
I used this stuff
http://www.ebay.co.uk/itm/251336535477? ... 26_rdc%3D1
Don't know how good it will be but my thinking is something is better than nothing.
Then I was interrupted by my daughter school phoning wanting me to pick her up early as she want feeling very well, was quite well timed though as it gave the mat time to dry.
The mat went back in next
Cleaned up well but the holes on the drivers side let it down, shame they're not available new any more
Then the seats went back in
dirtydog
Postby dirtydog » Thu Oct 02, 2014 10:23 pm
Well I've been avoiding the things that I should be doing to the van, mainly welding new passenger wing etc and have been doing a few other bits instead...
Fitted some mondeo vanity lights and put led bulbs in them
Mini led spot lights in the cab
Lights off
Lights on
Fitted a little cubby hole thing in the spare space under the stereo, liked this one as it closes :oops:
Also took the 2 flouro tube lights out of the back and have replaced with led lights, forgot to take a picture though
These are the old lights
dirtydog
Postby Mr RVM » Fri Oct 03, 2014 5:39 pm
Lookin Good Dogster 8) Mat looks good (despite the holes in the drivers heel pad) you could bond a piece of cut rubber from a cheap mat set onto the "affected" area :?: it would do till you find a new one (still turn up now and again) or a good used one (ive just got hold of a used one less than a year old with no wear £30 :) )
Soundproofing material looks like good value (not the best/thickest but cheeeeeeeep at the price £22 for a 16ft roll delivered :) ) and as you say, its got to be better than none at all so I'm having some of that :)
Mr RVM
Postby dirtydog » Fri Oct 03, 2014 7:53 pm
Yeah the mat scrubbed up quite well, have ordered one of these
http://www.ebay.co.uk/itm/FORD-TRANSIT- ... 4aa3c3eadf
Will put some foam in the holes and then put the carpet down.
As for the sound deadening, no definitely not the best or thickest stuff but compared to the price of dynamat etc then I'm fine with that :lol: That 5m roll was just enough to do the cab floor so I'll order another few to do the rear when I get that far. Might even take the door cards off and put some in the front doors as well but we'll see about that :oops:
Hoping to start on replacing the passenger side inner and outer wing and arch next week, bought the panels from Tim ages ago and they've been up in the loft since then.
Need to get a move on as the other half is getting a bit narky about me using the car all the time :roll:
dirtydog
Postby RustWidow » Fri Oct 03, 2014 11:11 pm
Doing well dirty, well done
RustWidow
Postby dirtydog » Tue Oct 07, 2014 10:22 pm
Remembered to take a picture of the lights in the back tonight
And yes I know it's a sh*t tip in there at the moment :oops:
Need to tidy the wires up a little bit and move the switch as I didn't think about it when I fitted. Wasn't until tonight when I needed to turn the lights on and couldn't reach the switch that I realised I put it in a crap place! :roll:
dirtydog
Postby dirtydog » Sat Oct 25, 2014 6:41 pm
We'll today I decided to get my finger out and actually do something with it today, there's plenty of jobs to be done!
First job was the gear box oil, bought the oil about a year ago :oops: the old stuff was pretty dark and manky
Then I took the propshaft apart to replace the bearing, the old one came off in pieces :roll: but I forgot to get a replacement bearing and the of course the local ford dealer parts dept closes at lunch time :oops: . Getting a ford one as I'm hoping it will last longer than the last one.
Then thought it would be a good idea to take the front apart to start replacing the wings, bumper and grill.
I've got a new bumble, grill, and passenger side wing, inner wing and sill panels.
The passenger side is definitely the worst side.
dirtydog
Postby dirtydog » Sun Oct 26, 2014 6:11 pm
Have been busy with the grinder today,
The wing had obviously been replaced before as it was pretty much just stuck on with seam sealer :shock: was only welded on at the slam panel and a couple of plug welds near the A pillar, on the plus side that made it pretty easy to get it off :lol:
Might as well replace the battery tray while I'm at it
Also got around to swapping the passenger side rear door, I got a replacement about 18 months ago and only sorted it a couple of months ago
Colour match is a bit off but that may also be down to the rest of the van being filthy :oops:
dirtydog
Postby dirtydog » Sun Oct 26, 2014 6:50 pm
Wasn't much left of the inner wing
And that was before I cut any of it out :shock:
dirtydog
Postby dirtydog » Mon Oct 27, 2014 8:43 pm
Well staying true to the thread title I made a little more progress today
Well I cut more rot out
And new metal welded in
That's about as far as I got this afternoon as I ran out of mig wire :roll:
And a quick test fit before I packed up
dirtydog
Postby RustWidow » Tue Oct 28, 2014 12:14 am
Well done dirty, slow but sure, I'm sure you'll get some more wire soon
RustWidow
Postby dirtydog » Tue Oct 28, 2014 12:16 pm
Thanks, it's slow going but I'll get there in the end
Just found a roll of wire in the garage as well so can get a bit more done this afternoon if I get work finished early enough
dirtydog
