I'm back ! , not from the dead but almost..
I know it's been over six months since I wrote anything about my project
, and for that I'm sorry. I was actually worried that my membership had been ended..
My recovery truck project has been delayed for several months due to other cars that has needed my attention, anyhow here's som new pictures..
The new front end is now put together with the rear part of the frame.
Carefully welded and when measured diagonally between the front and rear axle, the distance is the same within 2mm on left and right side. I think that is accurate enough..
As the frame is ready ( more or less..) the rust in the cabin will be fixed.
I've begun to fix the rust in th rear part of the front fender, it was not as bad as I thought.
Here you can see the hole
And here the rust is removed
welded and ready, the piece of the fender that is missing will be fixed tomorrow and welded together with the rest.
Hopefully the updates will be more often now, I've started my 4 week summer holliday so the days that it's raining will be spent in my workshop..
Be good and see you soon / Fredrik
