my custom/camper SWB twink project
Re: my custom/camper SWB twink project
Postby ray900tap » Sun Jan 12, 2014 10:31 pm
Mattblackminibus, thank you, but I'm far from a genius, I've just been lucky enough to work with some real genius's in everyday working life..
Luke, any more info please? I'll get the front in the air tomorrow and have a good look, I wasn't planning on using the mk3 hubs, but I was about to modify the mk3 wishbones.. It'd be nice to "just" bolt the subframe in place once painted aha, cheers for the heads up
Cheers dannyboysean, I do struggle with mojo sometimes, it helps with positive comments! Seems a never ending task aha
ray900tap
Postby ray900tap » Sun Jan 12, 2014 10:35 pm
Ha,sorry, forgot to answer your question Matt, pretty useless at this forum stuff..no, I didn't weld the spring hangers in place, I fitted new bushes and used high tensile plated bolts
Thanks again
ray900tap
Postby Luke » Sun Jan 12, 2014 11:32 pm
ray900tap wrote:Luke, any more info please? I'll get the front in the air tomorrow and have a good look, I wasn't planning on using the mk3 hubs, but I was about to modify the mk3 wishbones.. It'd be nice to "just" bolt the subframe in place once painted aha, cheers for the heads up
i cant remember exactly - might be worth an ask in the mk3/4/5 section :idea: - but the front bolts are 12mm on the mk3 and 10mm on the mk4/5 i think the wishbones might be the same but not sure - the struts hubs and top mounts are different :)
Postby RichH » Mon Jan 13, 2014 8:14 pm
This is my fave Mk5 ever. 8)
http://www.rhdoorsandshutters.co.uk
Automatic door and roller shutter specialists.
RichH
Postby jr71 » Mon Jan 13, 2014 11:17 pm
Hi Ray900tap,
The camper you bought used to belong to my m8. He was left it in a will. I have emailed him pics of the roof on your van.
Cheers Jay
57 plate transit connect
V reg mk5 transit (gone for restoration to Durham)
56 plate mk7
jr71
Postby MONSTER 0NE » Fri Mar 07, 2014 8:17 pm
Evening Ray, what shocks you using on the rear axle ? cheers
MONSTER 0NE
Postby Mr RVM » Sat Mar 08, 2014 2:57 pm
AlanN will be able to confirm the differences as he's swapped a Mk5 wishbone onto his Mk3 but he did say that it shifted the wheel position (cant remember if he said back or forward :?: ) about 15/20mm
Mr RVM
Postby MONSTER 0NE » Tue Jul 08, 2014 12:16 am
saw this van in person earlier, and its a credit to you Ray, and it does go well keeps up with my twink lol
MONSTER 0NE
Postby ray900tap » Sun Aug 10, 2014 10:43 am
good meeting you and your van andrew, loved that little play up the dualer aha..
ok, hold tight fellas, I may only be making an update aha..
so its the never ending rust chasing, these things sure like to rot!
bought a few panels off ebay, started with the lower O/S middle section
then more cutting...
I made an inner sill section from the roof panel I cut out
treated and zinc primed, maybe itll hold back the rot till the next MOT :lol:
the cheapo lower panel wasn't even close to the right shape or radius, but hey, £12 shouldn't complain aha, so I made a template to show the radius, then used the shrinker stretcher at work to gain the correct panel shape
(crap pictures but you get the idea)
the centre of the panel was still off, and I really don't want it full of filler if/when I paint the ol'girl.. so...
on to other repairs..
more recycled metal
(shhhhhh... don't say anything, but I've actually welded in my arches :shock: )
once the front subframe is finished and fitted, this is the goal!
talking of the front subby... not sure if I'd posted this picture before?
few other little pictures..
wheel bearing collapsed, so thought I clean everything up seeing it was out
interior back in, for now aha...
latest news, I May have scored a granada ultima cosworth V6, engine is still running in the car... could anybody please be kind enough to send links to threads where this has already been done? I've searched loads but I'm drawing a blank? this is 100% the route I'd like to go, did I mention the Eaton supercharger I've kicking around? :twisted:
cheers
Ray
ray900tap
Postby RustWidow » Sun Aug 10, 2014 10:47 am
Wow what a job! Well done! You know you'll need the wiring for the cosy engine don't you? And the brain.... But good luck, loving what you're doing.
RustWidow
Postby MattBlackMinibus » Sun Aug 10, 2014 10:51 am
Hasn't Luke still got his old engine for sale? With conversion kit and twin turbos? ;-)
"Hey Luuuke..."
Starting All Over Again
MattBlackMinibus
Postby ray900tap » Sun Aug 10, 2014 10:59 am
MattBlackMinibus wrote:Hasn't Luke still got his old engine for sale? With conversion kit and twin turbos? ;-)
"Hey Luuuke..."
cheers fellas 8)
could be interested, just did a quick search, was it in the forsale section?
ray900tap
Postby MattBlackMinibus » Sun Aug 10, 2014 6:25 pm
No, I think he just mentioned it in passing on a thread. Best to message him
MattBlackMinibus
Postby MONSTER 0NE » Sun Aug 10, 2014 9:50 pm
The little drive back to the M40 was interesting, shame we kept getting blocked by other inconsiderate drivers stopping us properly see which was quicker lol
MONSTER 0NE
Postby RustWidow » Sun Aug 10, 2014 11:45 pm
North Weald... Here you come lol
RustWidow
