IgorVigor wrote:I could be wrong though :S
I know the turbo di is 18.3:1
But I thought I read the N/A is 19:1...
(could be in the manual I read it)
FEEZ92 wrote:Ford's data sheets say:
N/A is 20.8:1
85ps turbo is 19:1
100ps turbo is 18.3:1
115ps turbo is 18:1IgorVigor wrote:I could be wrong though :S
IgorVigor wrote:Whaf exhaust will you be running?
Because a larger bore exhaust with no restrictions (so either no silencer or straight through) will lower the EGT's.....
And your big intercooler will keep the charge temp down which in turn will keep the egts down.....
Most of all though keep the smoke down a bit
I know a big plume from a turbo diesel looks good....but it will increase EGTs!
You could however.....fit a water injection system.....
robbie.cee wrote:FEEZ92 wrote:Ford's data sheets say:
N/A is 20.8:1
85ps turbo is 19:1
HAHAH I KNEW I AM ONLY SLIGHTLY MAD!
robbie.cee wrote:I think the same book stated both!
