Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby Luke » Wed Jul 03, 2013 10:54 pm
AlanN wrote:Good and bad news then :?
yeah i know what to check now but i cant remember if i looked at it before :roll: - its a solenoid in the box - i checked the feed definatly but i can't remember if i checked the ground as its done by the ecu - i think it might be this what isnt working - hopefully i didnt test that last time as i would have wrongly assumed that as its ecu controlled it was working ok :roll:
just wish i'd found this before i dropped the damn box :evil: :evil: :lol:
Postby Luke » Thu Jul 04, 2013 11:15 pm
well................................ i've found the problem :mrgreen: :mrgreen: :mrgreen: 3 boxes later it was the torque converter lock up solenoid not getting a correct feed from the ecu - ive yet to sort it fully - ive just been driving it round with a wire loose that i just touch on the dash to pull in the solenoid but its working :lol: i think it was me removing the traction control that has caused it but i need to do a bit more research before i can be sure but.............. NORTH WEALD HERE WE COME 8) 8) 8) 8) 8) 8) 8) 8)
Postby madbri » Fri Jul 05, 2013 6:33 am
now this alone could be worth going to north weald 8) 8) 8)
well done hope it is sorted.
madbri
Postby AlanN » Sat Jul 06, 2013 7:12 pm
Brilliant news Luke, hows it sounding, like a Jap?
Postby Luke » Sun Jul 07, 2013 10:43 pm
just been reading back a few pages and nearly a year and 3 gearboxes ago i was onto the right thing :roll: :lol:
Luke on 4th Aug 2012 wrote:update :!: still not right :roll: pritty sure the problem is wiring related re. the autobox - i think its the 'lock up solenoid' you can be travelling at 50mph boot it the box kicks down the engine revs up but there's little increase in speed :!:
AlanN wrote:Brilliant news Luke, hows it sounding, like a Jap?
sounds loud without the exhaust on the wastegate :lol:
got the rev counter working today 8) also fitted a boost gauge, did a few practice runs and it's not perfect but good enough to put a big smile on your face :mrgreen: :mrgreen:
Postby Luke » Sat Jul 13, 2013 10:01 am
sort of ready for north weald :lol: - some odd stuff going sometimes it pulls like a train sometimes it seems to make a lot of noise and not be particuarly fast but i've got a better idea nowof whats happening as ive got speedo (acurate too :shock: ) and temp gauge and boost gauge all wired in - i think there is more to go with the van but if i can beat my old time i'll be happy for this run :D
also put a temparary wastegate pipe on and spent 3 hours fitting the bumper back on - it meant re-mounting the radiator but it does look so much better now :mrgreen:
Postby madbri » Mon Jul 15, 2013 10:12 pm
:roll: :roll: come on tell us ure thoughts on ure results from weekend
madbri
Postby Luke » Mon Jul 15, 2013 11:00 pm
bad................ :roll:
managed to get over 50mph this year tho - 89 mph over the line was good tho but 17.89 wasnt
i think i was loosing boost through the wastegate but ive blanked it off tonight and its not that much better - the main problem is i cant spin the engine fast enough to make any boost off the line and the lag is killing it :roll: i need a higher stall torque converter and/or better tyres :|
or a manual box :(
and i forgot............. last run we had an electrical issue in the line up rushed to sort it got to the line forgot the bonnet wasnt closed set off half way down the strip it flew up - 1 new bonnet reqd :x
Postby AlanN » Mon Jul 15, 2013 11:14 pm
Oh crap, I bet that was a frightner... :(
Postby Guy88 » Mon Jul 15, 2013 11:22 pm
is your smaller turbo ok,
If its all working as it should there should be hardly any lag :? :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Jul 15, 2013 11:23 pm
i couldn't fit the twins in the engine bay guy had to go single :)
Postby Guy88 » Mon Jul 15, 2013 11:25 pm
Luke wrote:i couldn't fit the twins in the engine bay guy had to go single :)
get the small one fitted somewhere and some pipes :twisted: :twisted:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Jul 15, 2013 11:25 pm
AlanN wrote:Oh crap, I bet that was a frightner... :(
2nd time its happened :roll: it was worse 1st time when it happened on the M1 :lol:
Postby Luke » Mon Jul 15, 2013 11:27 pm
i would have to direct the flow through it to spin it up 1st - i could just fit some nitrous :lol:
Postby AlanN » Mon Jul 15, 2013 11:28 pm
Definately dont want to experience that one, we are looking out for a bonnet for you
