Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby Guy88 » Mon Jul 15, 2013 11:32 pm
Luke wrote:
Guy88 wrote:
Luke wrote:i couldn't fit the twins in the engine bay guy had to go single :)
get the small one fitted somewhere and some pipes :twisted: :twisted:
i would have to direct the flow through it to spin it up 1st - i could just fit some nitrous :lol:
this is my plan for the spec, going to use the small one strait onto the manifold and then remotely mount the big one 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Jul 15, 2013 11:41 pm
on the plus side on the drive down and back home it was great 70-80 no problem revs at 2500rpm @70mph loads quieter than the cossy was :D
Postby MinorMatt » Tue Jul 16, 2013 9:56 am
fit a nitrous jet pointing at the outside of the compressor vanes... when you hit the loud pedal the nitous will spin up the turbo for you and deliver it to the combustion chamber!
Postby Luke » Tue Jul 16, 2013 8:49 pm
MinorMatt wrote:fit a nitrous jet pointing at the outside of the compressor vanes... when you hit the loud pedal the nitous will spin up the turbo for you and deliver it to the combustion chamber!
been reading about using nitrous on the supra forums but i wonder if i could do that idea using just compressed air :?: :idea:
Postby madbri » Tue Jul 16, 2013 9:10 pm
like a soda stream bottle or a small welding bottle?
madbri
Postby limitedblack » Tue Jul 16, 2013 10:09 pm
Did you read my post reference "bang bang" theory, this changes ignition timing to produce combustion in exhaust manifold, thus spooling up turbo before launch. Would have thought some kind of second crank sensor or delayed circuit could be rigged up to try it out ?
Happy Easter
limitedblack
Postby Guy88 » Tue Jul 16, 2013 10:10 pm
anti lag, get a rather nice noise too 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Tue Jul 16, 2013 10:37 pm
limitedblack wrote:Did you read my post reference "bang bang" theory, this changes ignition timing to produce combustion in exhaust manifold, thus spooling up turbo before launch. Would have thought some kind of second crank sensor or delayed circuit could be rigged up to try it out ?
yeah i did ......... still am :lol:
problem is 99% of the time the van will be driven nice and steady on the street - i'm thinking this is a bit too much hassle too complicated to give decent reliability :? :)
Postby Guy88 » Wed Jul 17, 2013 12:30 am
Most cars that have anti lag have a switch to turn it off
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby limitedblack » Wed Jul 17, 2013 4:01 pm
Guy88 wrote:Most cars that have anti lag have a switch to turn it off
That's what I was thinking, just activate for 1/4 mile launches. A magnetic reed switch is easy mod for 1st gear sensing, then just something to fool the timing, but make sure your exhaust clamps are on tight :lol:
Happy Easter
limitedblack
Postby limitedblack » Wed Jul 17, 2013 9:30 pm
12v air bed pump ?
Happy Easter
limitedblack
Postby Luke » Sat Aug 03, 2013 8:43 pm
progress since weald it was suggested to sort the van out one option would be to get it on a rolling road, so i thought if i'm going to do that i would get the charge cooler fitted and piped up :D the top water pipes were all in temporarily so while i'm doing the charge cooler piping ive got all the hoses to do that :D
the charge cooler is away being welded together, i've cut it up to get a better smoother flow, it should be done next week.
while i was looking over the engine i noticed a pipe at the back of the plenum wasnt connected to anything :shock: and never has been since i've put the engine in its about a 6mm bore pipe so it could account for a lot of the lag :idea: i'm suprised it even ticked over :lol:
quite looking forward to getting the charge cooler back now to see how much difference blanking this pipe off has made :D
Postby MONSTER 0NE » Sat Aug 03, 2013 10:15 pm
Nice to see some positive progress on the van, but you like Luke leaving pipes disconnected LOL
MONSTER 0NE
Postby MattBlackMinibus » Sat Aug 03, 2013 11:11 pm
Result.
Thought the slipping box was the main issue though?
Starting All Over Again
MattBlackMinibus
Postby Luke » Sun Aug 18, 2013 10:56 pm
MattBlackMinibus wrote:Thought the slipping box was the main issue though?
yes definatley 2 different issues :)
Been a bit, we very busy lately so not had much time to spend on this but i have managed to get hold of a bonnet (thanks matt 8) ) not mint but will tidy up :D - fitted it today won't be in paint for Transitmania 5 :( but the catch is on so it wont flip up :lol:
I need to get an MOT this week so i'm getting it ready for that (hopefully they can fit me in) the charge cooler mods have been done so i should get a chance to collect it tomorrow - i'll post up a pic :D
but the big news is :!: :!: :!: :!: - i took it for a little run up the road with the boost leak sorted - and it spun up under hard acceleration - which it hasnt done since i had the cossy in :mrgreen: :mrgreen: so i have high hopes 8)
after Transitmania 5 is over i'm going to sort out another drag meet to test it if anyones interested??? stu also fancy's taking the YB mk6 out again after fixing his turbo he thinks he can improve too :mrgreen:
