loving the work alan,
quality as always,
rover wrote:Cracking work as always Alan![]()
You need a can of Grip4 to help the paint adhere properly, then depending on how smooth you want the finish (smoother finish=more sanding) you need several layers of primer/filler, then a couple of top coats (twin pack or celly):wink:
Rover.
AlanN wrote:A friend of mine told of a motor shop that sell the full range of U-Pol products including grip 4 and its only about 15/20 minutes away, so Im going to pop in there on the way home tonight to see if its cheaper than eBay.
rover wrote:AlanN wrote:A friend of mine told of a motor shop that sell the full range of U-Pol products including grip 4 and its only about 15/20 minutes away, so Im going to pop in there on the way home tonight to see if its cheaper than eBay.
Thats the stuff you really need, its what a lot of the body shops around here use so it must be good stuff, its also what I used to when I did mine....
Beware though...Supermarket trolleys still take the paint off![]()
Cant tell you what happened to the 'youf' that shoved the trolley into my front bumper but he WILL think twice before doing it to anyone else
Rover.
