dieselhead123 wrote:The 'cunning plan' does include trying the center part of a Mk3 crossmember RVM, but the whole thing is too long to use complete and the outer ends of the Mk3 are tapered back more.
Once a bit more of the rot is cleared away we will see how similar it is.
The chassis rail tops do look to be similar to the Mk3/4/5 ones, I have one in stock to compare and have already produced a CAD drawing to enable these to be copied. I am sure we will have to remove the steering box mounting from the inner wing to complete this part of the repair.
We all know that Mk3 front spring hangers can be modified to suit the Mk2, so perhaps it is not as bad as it would appear.
The only thong I am unsure of is the correct appearance of the front cross member closing panel, there is nothing left of the original, is it just a 'flat' cover![]()
Yes I did that on mine, just drilled out spot welds completely and used bolts (8mm) to fasten it back in, the base on the Mk3 vesion is bolted anyway
Front cover Appears to be just flat (so making one to suit will be cheaper than buying one (had a look at some of Muttley's but couldn't see as he keeps stickin a fookin great big bumper in the way
