Mk6-mk7 Conversion No 2 2006 Transit T280 100ps (PIC HEAVY)
Re: Mk6-mk7 Conversion No 2 2006 Transit T280 100ps (PIC HE
Postby paul2012 » Fri Jul 10, 2015 6:53 pm
tourneo newbie wrote:Can I get a copy of the wiper etc wiring diagrams please the ones without tow hook
Standard Ford wiring diagrams :?:
Or
My reworked wiring diagrams for fitting mk7 column switchgear in on a mk6 :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby tourneo newbie » Fri Jul 10, 2015 8:40 pm
Reworked ones please I've fitted mk7 dash to my mk6 thanks
tourneo newbie
Postby paul2012 » Sun Jul 12, 2015 11:02 pm
tourneo newbie wrote:Reworked ones please I've fitted mk7 dash to my mk6 thanks
Wiring diagrams/details for wipers, Hi/Lo beam, Flash to pass. PAT's transceiver, horn & airbag.
Are posted here :arrow: viewtopic.php?f=27&t=150664&start=510#p1327865.
Only the indicator circuits between WITH trailer tow attachment & LESS trailer tow attachment, are different.
I am currently working on wiring diagram & details for Mk6's LESS trailer tow attachment.
Once completed I will post details here :wink:
paul2012
Postby tourneo newbie » Mon Jul 13, 2015 8:36 am
Perfect I'll look forward to viewing them I've got all the dash in minus the steering column and wheel
tourneo newbie
Postby mrepson » Fri Jul 17, 2015 12:04 am
what air box are you using, :?: as I can not get the bottom air feed duct pipe to fit the mk6 airbox,as the mk7 headlight back is in the way, :?
mrepson
Postby paul2012 » Fri Jul 17, 2015 1:18 am
mrepson wrote:what air box are you using, :?: as I can not get the bottom air feed duct pipe to fit the mk6 airbox,as the mk7 headlight back is in the way, :?
I didn't fit air duct to bottom of filter box :wink:
paul2012
Postby paul2012 » Sun Jul 19, 2015 8:09 pm
Mk7 Steering column, wheel etc has been fitted.
Yes Mk7 ESP switch works the same way mk6 TC switch does :P
Just need to finished off wiring for column switch gear.
paul2012
Postby Collinm » Sun Jul 19, 2015 8:20 pm
Back on the job
Collinm
Postby karl » Sun Jul 19, 2015 8:22 pm
Collinm wrote:Back on the job
polishing ya knob :lol: :lol:
sorry couldn't resist :lol: :lol: :lol:
karl
Tranny Lover!!!
Postby Collinm » Sun Jul 19, 2015 8:24 pm
Oi, stop pipping.
Collinm
Postby paul2012 » Thu Jul 23, 2015 4:18 pm
mk7 squib has been wired up. Horn works & airbag light proves out as it should.
Changed the battery as it don't hold it's charge. Then doubled checked everything only to find that airbag continues to prove out then after about 10 seconds it flashing a code which repeats before light stays on :evil:
Cause is airbag they came with mk7 column & steering wheel. It's a 2 stage airbag.
I check it on my Trnasit just to rule out a faulty squib & ended up with same result.
So purchased s single stage one from ebay,
That one works fine :P
Wiring for main beam headlights & indicators is now complete. Will upload vid later showing operation. 8)
Now in the process of finishing wiring for wipers....
paul2012
Postby loot » Thu Jul 23, 2015 4:40 pm
Would you say the 2 stage bag is off something other than a mk7? Can't say I've ever seen 1 on a mk7 come to think of it i don't think I've seen 1 on anything :lol:
Ids map here
loot
Postby paul2012 » Thu Jul 23, 2015 7:21 pm
loot wrote:Would you say the 2 stage bag is off something other than a mk7? Can't say I've ever seen 1 on a mk7 come to think of it i don't think I've seen 1 on anything :lol:
Going by the part no. It's from an early C-Max :?
paul2012
Postby paul2012 » Fri Jul 24, 2015 9:16 pm
What's happen to the summer weather :?: Been raining here for the last 3 days :?
Anyway. wiring for wipers has been completed.
Uploaded a vid here showing mk7 Column switch gear working etc.
:arrow: https://www.youtube.com/watch?v=o9zW55V_2Ps
paul2012
Postby tourneo newbie » Fri Jul 24, 2015 9:20 pm
you need to put some fuel in that lol
tourneo newbie
