robbie.cee wrote:Any luck with the leccy yet have you decided which ecu your gonna use?
robbie.cee wrote:I'd keep it ford ecu where possible. . If you wanted later could upgrade to mega squirt but get it running first.
Plenty of info regarding pin outside of ecu. Think euro 5 ecu or pcm as now called eec v has 104 pins where as the older eec iv ones are 60 pin. The extra 46 pins in newer ones are related to the extra emission control shyte
robbie.cee wrote:Re vvt output... I have a similar obstacle to overcome...
Yours is vvt triggering ...
Mine is operation of the viz (inlet doobery to lengthen or shorten intake distance all techy bullshit)
My viz thing needs to activate at 3200 rpm so I need a trigger to switch vac solenoid at said rpm...
Reading up on cossie Conversions on www found people using "rpm window switch"
Which basically switches so.ething on or off at a given rpm....
Wires into either tach output from ecu or from rpm pulses from the alternator.....
May be worth a look
Msd ones are about 90 quid on fleabay
pat stevens wrote:that sits in the engine bay nice.had to remove a lot of bulkhead to fit mine
