Loots Asbo 130ps
Re: Loots Mk7 130ps
Postby Cider Andy » Fri Aug 02, 2019 4:43 pm
You've had yours five minutes.
I've had mine nearly two years.
Slow down man!
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 5:41 pm
Well Mr cider Andy i have good news :P
let me take you on a little adventure 8)
This morning and previous mornings the van has been cutting out, I mean as soon as I dip the clutch it dies even if I floor the gas, the other day it cut out crossing a dual carriageway Image
Today I fitted your scv and your pressure sensor and your prv, couldn't get a bolt out of the old trail so had to swap them over.
I also did a leak off test, I also fitted the rocker seals, injector copper washers and green o rings.
I did it all slowly and I used lots of the 40 stuff and a blue roll.
I tied cables up, I checked connectors and I noticed that the air pipe that clips to the filter box was very loose so I used some of that sticky foam tape around it and it snugly went on. I tightened up the jubilee clips etc.
Now I haven't done the programming but it is purring like a kitten. 8)
I think it should pass the learns now.
Injectors look good too.
So to recap, this van looks a bit rough but the floor is solid and now the engine is sweet. 8) so what was a lemon for the previous owner is so far coming good. 8)
Also I fitted a new cht.
Ids map here
loot
Re: What did you do to your mk6/7 today?
Postby Airthies » Fri Aug 02, 2019 7:09 pm
Looking good man
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 7:11 pm
I'm a idiot, ids laptops x 2, vcm2 x2 no connection, reset them etc.
Only blown f72 :lol:
Learns now wish me luck :P
Ids map here
loot
Re: Loots Mk7 130ps
Postby ned » Fri Aug 02, 2019 7:13 pm
Don't trust your moonshine bottles :shock: :lol:
I've just had a wonderful idea :!: Now Me Loot 1 van of Wales seems to get things done quickly so if I leave Lucifer outside looter maybe it'll be mended in a few hours :lol: :lol:
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Loots Mk7 130ps
Postby blue estate » Fri Aug 02, 2019 7:18 pm
loot wrote:I'm a idiot, ids laptops x 2, vcm2 x2 no connection, reset them etc.
F72 was the first thing I changed on trampy as the interior lights didn't work :roll:
blue estate
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 7:19 pm
Maybe :P or maybe lucifer will be on to me as soon as he's near my place and he'll commit harry carry :shock:
Ids map here
loot
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 7:20 pm
Just to make me look more of an idiot I removed the bulbs the other day and not very carefully and they were hot and I left them dangling down :lol: so most likely I made a rod for my own back :roll:
Ah well.
Ids map here
loot
Re: Loots Mk7 130ps
Postby ned » Fri Aug 02, 2019 7:32 pm
Harry carry you say :shock:
Well it'll just be reborn more evil
ned
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 7:47 pm
:lol: that better not be it smashing out of the lair :shock:
Ids map here
loot
Re: Loots Mk7 130ps
Postby ned » Fri Aug 02, 2019 8:08 pm
:lol: :lol: it'll save you making a door opening for the lair.
ned
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 8:17 pm
:shock:
Right my van runs sweet and the pump learns ok then the pilot fails halfway, code 80 then code 93 injector 4 restricted.
Tried a couple of times and then anob head neighbour shouted shut up with that van lol cheeky cnut :? Not like we have to hear his family screaming in the Street is it :roll:
Anyway I've gone for fish and chips 8)
Ids map here
loot
Re: Loots Mk7 130ps
Postby Cider Andy » Fri Aug 02, 2019 8:58 pm
Heh heh, happy days! Newest bit of your van now, that fuel rail!
Cider Andy
Re: Loots Mk7 130ps
Postby loot » Fri Aug 02, 2019 9:12 pm
Ah i couldn't use the rail unfortunately :( I'm getting there slowly though, apart from the engine malfunction warning on the speedo it seems fine now.
Ids map here
loot
Re: Loots Mk7 130ps
Postby Cider Andy » Sat Aug 03, 2019 12:32 pm
loot wrote:....apart from the engine malfunction warning on the speedo....
Yeah, I got that too!
Largely because most of the engine is in a cardboard box in the back.
Cider Andy
