My Landliner
Re: My Landliner
Postby Chaz&Saz » Thu Feb 26, 2009 7:02 pm
I am thinking it has sat in the damp. might try starting it in gear again with the pedal wedged down but will need some pushers as the starter does not have enough power to shift the van with the binding brakes.
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
Chaz&Saz
Re: My Landliner
Postby Muttley » Thu Feb 26, 2009 9:05 pm
Its difficult to do but I have had some succsess by bump starting then driving along with the clutch depressed and jumping on and off the accelerator :shock: It worked for me :wink:
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Re: My Landliner
Postby VWPowered » Fri Feb 27, 2009 8:01 pm
wow, looks a sweet project that 8)
83 Polo 2 1.3 GT Coupe - 83 LT 2.4D Petit Camion
91 Polo 3 1.3 Bel-Air - 93 Golf 3 1.4 Europe
98 Passat 1.8T Break 'en route' - 96 Pikey Transit SWB 2.5Di
http://www.franco-oldtimers.com - classic cars 'en france'
VWPowered
Re: My Landliner
Postby PJR » Thu Apr 23, 2009 4:59 pm
Following this with interest
I really need to get Emily back out on the road, once i can get the front end welded :(
PJR
Re: My Landliner
Postby Chaz&Saz » Sat May 02, 2009 6:51 pm
Some progress at last!
Now its a long weekend i have decided to do some work,
Yesterday i removed the front end and lifted the engine out giving me a chance to look deeper into the rust which is not that bad :). Now I'm able to look at the bulkhead its not as bad as i thought. Big issue is the front valence and the member behind it.
With the engine in the hoist i could finally get at the clutch which needed some taps with a hammer while leavering the pressure plate off then dropping the pressure plate on the floor from about a foot up, to jar the friction disk off. All the parts look good but will replace the spigot bearing.
I then got a phone call saying the MIG welder i was borrowing was available, so went and collected that and had a quick welding lesson, as its been 10 years since i MIG welded.
Maybe going to the Bristol show/autojumble tomorrow so be looking for goodies need a 6 branch exhaust. . . .
More to follow
Charlie
Chaz&Saz
Re: My Landliner
Postby Muttley » Sat May 02, 2009 7:05 pm
Where is this auto jumble? I fancy a browse too :D
Muttley
Re: My Landliner
Postby Chaz&Saz » Sat May 02, 2009 8:31 pm
For info go to www.bccsl.co.uk Think its more of a show than jumble but never been
Chaz&Saz
Re: My Landliner
Postby Chaz&Saz » Fri May 08, 2009 3:16 pm
After the engine sitting in the corner of the build room for a week i have lifted the heads off for a look inside. All looks quite nice in there one of the cyl's was a bit damp and dark but nothing nasty. Have rebuilt one of the heads already the valves, guides and seats look good. hopefully knock the sump off for a look at the bottom end soon.
Just waiting for some power points to arrive so i can plug the welding plant in and get on with the important bits :)
Charlie
Chaz&Saz
Re: My Landliner
Postby Muttley » Fri May 08, 2009 9:56 pm
Good luck and may the force be with you :D
Muttley
Re: My Landliner
Postby Chaz&Saz » Mon May 11, 2009 10:44 am
Thanks for that Muttley. Am looking forward to getting the welding done so i can get on with the oily bits and finally drive the van.
Chaz&Saz
Re: My Landliner
Postby Chaz&Saz » Sun May 31, 2009 9:41 pm
Picked up 2 doors and a good wing yesterday. Lucky to find them locally too. The garage selling them had a very smart LWB panel van that they had used for the last 37 years.
One door needs a minor repair to the lower skin and the other is fine. The wing is very good just needing the headlight bowl repairing.
I now have the engine partually stripped, It has been rebuilt at somepoint in the past as the manifold does not match the heads and the con-rods are factory numbered but not in the right cyls. one of rocker adjusters is very worn and the cam and followers are shot. I have a new cam and followers on sale or return depending on the rest of the engine. It will need a set of rings. The only bearing i have looked at is in very good condition so hoping it wont cost a lot to get sorted and running well.
Chaz&Saz
Re: My Landliner
Postby Muttley » Sun May 31, 2009 9:45 pm
Sounds good, if it turns sour though I have a good rebuilt essex for sale :wink:
Muttley
Re: My Landliner
Postby Chaz&Saz » Tue Jun 09, 2009 12:49 pm
Stripped a little more of the engine last night. Found a broken piston ring but the bore has no marks. Was feeling pretty pleased with it until i found it was a short stroke 2.5ltr unit. . .There are a few 3ltr on the bay all i need is the crank and pistons but will prob get a whole engine as i want flat heads too.
More to follow Charlie
Chaz&Saz
Re: My Landliner
Postby madmark » Tue Jun 09, 2009 12:51 pm
:shock: dont here of many 2.5ltr anymore ,the porblem they looked the same as the 3ltr,same as the 1.7v4 and 2ltr :roll: :roll:
Re: My Landliner
Postby Chaz&Saz » Tue Jun 09, 2009 3:41 pm
The blocks are the same so can be pot luck what you end up with. What was the 2.5 used in? as its in reasonable condition i might recon the bottom end and list it on the bay to finance the rest of the build
Chaz&Saz
