Rob Cee's transit - start of makeover
Re: Rob Cee's transit - start of makeover
Postby AlanN » Tue Feb 07, 2012 9:35 pm
Why didnt you just unplug the holder and turn it around, or is it one of the T shaped ones
Postby transitandy » Tue Feb 07, 2012 9:41 pm
Love the new wheel 8) 8)
Postby robbie.cee » Tue Feb 07, 2012 10:53 pm
AlanN wrote:Why didnt you just unplug the holder and turn it around, or is it one of the T shaped ones
yes polarised so tou cant, theres a locator dent in centre on bottom of face of plug!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby AlanN » Wed Feb 08, 2012 9:36 am
I tried to to look how I did mine, but the snow had been melting and frooze again and I couldnt open the doors :lol:
Postby captain hook » Wed Feb 08, 2012 7:13 pm
AlanN wrote:I tried to to look how I did mine, but the snow had been melting and frooze again and I couldnt open the doors :lol:
Wasn't it Mk3 Fiesta bulbholders we fitted 8)
captain hook
Postby robbie.cee » Wed Feb 08, 2012 9:20 pm
heheh i just chopped and spliced the damn things. typical a bloody motor company mix wires up and no one notices til 12 yrs later!
MY STEERING WHEEL BOSS JUST ARRIVED THIS MORNING WAHEY!!!!
also the retards at the dvla sent me bk nice new DIESEL 2.5 log book... apparently the letter explaining why is on its way 4 days ago...
TIM m8 gonna need that letter !!!!
:D
Had
MAKE IT FIT
robbie.cee
Postby BROWNYS V6 » Wed Feb 08, 2012 10:10 pm
just had to do a letter for mine rob :roll:
BROWNYS V6
Postby robbie.cee » Wed Feb 08, 2012 10:40 pm
I had to ring em to find out why no letter etc apparently its in the post but the log book made it bk first!??
Stupid bloody process if you ask me! dunno if ill bother telling em bout the essex :lol:
Had
MAKE IT FIT
robbie.cee
Postby dieselhead123 » Thu Feb 09, 2012 12:17 am
Hi Rob, will do the letter for you mate.
Standard procedure for dvla, they do not trust people to tell them the truth, this only happens with diesel to petrol engine changes, you need a letter from the garage that did the conversion, (me) :lol:
Postby robbie.cee » Thu Feb 09, 2012 12:19 am
:lol: Silly really cos it wouldnt be hard to find a dodgy garage who would just write a letter out for money :shock: :lol:
see ya tomo for a brew n starter etc! :P
Had
MAKE IT FIT
robbie.cee
Postby AlanN » Thu Feb 09, 2012 9:23 am
I registered just over a year back now, but I did it with the Essex DVLALO I was told it would be quicker, plus they didnt send a log book, just a letter. Still took a few weeks
Postby robbie.cee » Thu Feb 09, 2012 10:11 pm
The wheels are in motion so to speak.
Plus my wellers have been returned, all drilled and counter sunk!
just need sanding painting and rubbering now! might even be on for North Weald.
My hub is now ready for fitting up to the van on saturday- my DAY OFF yeah!!
New starter motor from Mr Dieselhead123 too so i might be running on sat/sun.
might even get the weber fitted too :D
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Sat Feb 11, 2012 3:07 pm
Well today, afetr a well deserved lie in til 10am, i got about 20 layers of clothes on and set to replacing my starter motor, as the 30 year old one was fooked.
Bearing in mind i thought id flattened both batteries, she turned over faster than ever before, nice noise not some grating dry sound then started with a cloud of diesel-contaminated-petrol somke!
HAPPY DAYS SHE LIVETH!
Next task was to fit my new steering wheel. I went up the road and back to ensure wheels were straight as can be then popped original Ford wheel off with a 22mm socket(use small screwdriver to remove centre cap).
Eye-ing the new wheel up as straight as poss i pushed the wheel onto the First tapered bit of the spline. A few twists slightly each way to be sure then pushed gently but firmly a few times then removed wheel. I could clearly see the two now mullered splines so i wiped off the bits from the hub and spline.re fitted then I drifted the hub downthe rest of the way with the 22mm socket on the extension bar. Removed again, cleaned up metal, checked fits tight onto spline then tightened nut back up!
I did of course have to removed the Quick release steering assembly from the (MK1 Escort) hub to bolt on to the steering column.
Check this out, I am well happy. will take a bit of getting used to extra effort to turn wheels and smaller size slightly in way of clocks but i can still see all the same!
Yeah baby YEAH :P
Had
MAKE IT FIT
robbie.cee
Postby MattBlackMinibus » Sat Feb 11, 2012 3:15 pm
Nice mod geez, looks smart 8)
Happy days getting the pinto running :D :D
Forget the essex, just tune up the pinto ... loads a power!
Starting All Over Again
MattBlackMinibus
Postby robbie.cee » Sat Feb 11, 2012 7:19 pm
Well today has certainly been productive. new starter, steering wheel and i finally fitted the Weber 32/36 today too. Nearly didnt but i said to myself if the bolts are easy to undo ill do it- the engine bay was toasty warm too so i cracked on only took bout hour with a lot of faffing around! was helpful that i actually had all the bits i needed, bar 2 jubilee clips which dont matter as only fuel return will fit tommorrow.
Cam belt change tomo too so we will see if the timing issue is belt related or just shyte motorcraft distributors!!!! :D
Had
MAKE IT FIT
robbie.cee
