My 2.5 TDi project
Re: My 2.5 TDi project
Postby FEEZ92 » Wed May 02, 2012 12:50 pm
I have the Haynes book and it states that the N/A has 19:1 ratio but the ford specs give 20.8:1
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby robbie.cee » Wed May 02, 2012 8:17 pm
Hey Feez dude hows it hanging? any more fun with the drift bus @6000 rpm? that vid still makes me smile never heard a diesel rev up like that before(although im sure your neighbours have, often!) sounds the nuts!
8) 8) 8)
what sort of bhp are you getting now with your mods to the govenor?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby FEEZ92 » Thu May 03, 2012 9:45 am
Hey lad, thanks! I don't know how much BHP yet, I'm building a new pump from the latest -146 model to hopefully get more juice into them cylinders!! :lol:
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby robbie.cee » Thu May 03, 2012 10:04 pm
MORE? your nuts m8 in a good way! should nick name you Murdock!! 8)
Had
MAKE IT FIT
robbie.cee
Postby IgorVigor » Wed May 23, 2012 2:39 pm
I doubt the power figure will be anythings special....
Its the torque that will be interesting :D
I'm also going to build a custom injection pump.....I need an LDA so I can get enough on boost fuel without leaving black clouds off boost :P
IgorVigor
Postby FEEZ92 » Wed May 23, 2012 2:48 pm
As long as I have big torque up to 5000 I'm happy.
The smoke thing is like marmite, you either love it, or hate it. Personally I love it :lol: :D
Also I like to get rid of anything in the pump that may restrict the absolute MAX the pump could deliver
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Thu May 24, 2012 3:55 pm
FEEZ92 wrote:As long as I have big torque up to 5000 I'm happy.
torque is more fun than power :D
as for the smoke....I love it as well :lol:
but sadly VOSA/MOT/nik niks/etc don't :roll: :cry:
so I try and keep it to a minimum off boost.... (I usually drop the revs down if I see the rozzers :lol: )
I'm going to build a custom pump soon....
just need to get another transit pump casing, and a clockwise throttle LDA top (most are anti-clockwise :()
I have a Land Rover 200Tdi pump in the shed to rob parts off (I will investigate the cam plate :twisted: )
I obviously have the LR LDA but the throttle is again the wrong way.....
just would have been nice to keep the transit throttle standard :roll:
the other option (the naughtier option) I've considered....is whether I could get a Bosch P/M/MW inline pump to fit fairly easily.....
oil feed wouldn't be an issue (I could fit another T piece below the pump :p)
EDIT:
By the way, how much did you shim the governor spring?
I will be doing the same, but I want fuel cut around 4,500rpm instead of 3,750rpm....
perhaps a little more....but the absolute max I would want is 5,000rpm....
just wondering how much you shimmed yours and what rpm your governor kicks in?
would save trial and error for ~1,000rpm more :lol:
IgorVigor
Postby IgorVigor » Sat May 26, 2012 12:11 pm
Doesnt matter....
I had the pump apart and took a gamble :P
added ~3mm of shims to the main spring and now have ~5,000rpm max revs
so 3mm seems to be a good shim size for those wanting a few more rpm...
Oh and dont forget that the shim also keeps more fuel going in until higher rpm so more power can be made :P
IgorVigor
Postby FEEZ92 » Sat May 26, 2012 12:18 pm
I shimmed it up until there was about 1mm movement in the governor, just enough to get it back together.
So my governor is pretty useless apart from for idle and mid range.
Dangerous I know but I have 2 spare lumps anyway :twisted:
Also worth considering is a stiffer spring, I used a VW Golf one before I shimmed it, gave about 5,250 max with cutoff starting about 4000 or so
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Sat May 26, 2012 4:05 pm
As long as your willing to be the engine speed governor....who needs one in the pump :P
mine is shimmed so I can just about get to ~5,000rpm...
Full fuelling to around 4,250 and then it starts reducing the fuel a little.
But it still keeps pulling well :)
Just need bigger injectors now :O
I cant increase the fuelling any more...
Without the gov mod its got plenty on 70ps injectors......
Just need to save for some injectors now......
Unless I can drill the holes a little :) :P
By the way, does anyone know the spray angle?
IgorVigor
Postby IgorVigor » Tue Jun 05, 2012 5:29 pm
Any updates Feez?
I was doing some research and found out how much air flow your turbo makes :D
around the 550~600CFM mark :D
mine doesn't flow quite that much :(
IgorVigor
Postby FEEZ92 » Sun Jun 17, 2012 11:03 am
Hi all,
Just got the oil and boost hoses plumbed up yesterday and took her for a spin :-)
Nice bit of extra torque.............. wait until I change the pump and injectors :lol: :lol:
Video from yesterday:
http://youtu.be/x0bV8-qWt44
Sounds like a truck lol
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Sun Jun 17, 2012 1:51 pm
FEEZ92 wrote:Hi all,
Sounds good :D
Mine sounds like a tractor/lorry engine :D
But I dont have any silencing :twisted:
It seems to perform a bit like mine.....great off boost and low boost....but runs out of fuel quickly.....
Hopefully your 130ps injectors will solve the issue ;)
Mine is now revving to 5,000rpm and 12psi all the way because my air filter was blocked :P
IgorVigor
My 2.5 TDi project
Postby FEEZ92 » Sun Jun 17, 2012 3:14 pm
Yeah it's gasping for more fuel. It barely makes any boost yet.
I need to make a side exit exhaust. The footwell gets very hot!
Also time to clean out the intake manifold and I doubt the boost hoses will take any sort of serious pressure
MORE BOOST!
MORE SMOKE!
FEEZ92
Postby IgorVigor » Sun Jun 17, 2012 3:47 pm
FEEZ92 wrote:Yeah it's gasping for more fuel. It barely makes any boost yet.
With the injection pump maxed on 70ps injectors and modified governor (5,000rpm) I still can get on boost smoke above 3psi :lol:
Mine goes well at 12psi....but 130ps injectors will be bought when I can :D
As for side exit exhaust....definitely a good idea :)
You can see the smoke then :lol:
Mine is basically a standard exhaust with a single silencer and 90 degree bend on the end.
No silencing material (empty box:P)
It quite restrained and quiet really.......
IgorVigor
