Loots Red custom
Re: Loots Red custom
Postby ned » Sun Apr 15, 2018 10:57 pm
Nothing is impossible and with your skill set highly achievable, the biggest issue is space. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sun Apr 15, 2018 11:11 pm
Well I'm close to perfecting shield technology and anti gravity but still quite far off yet. :shock: :lol: :lol:
Ids map here
loot
Postby ned » Sun Apr 15, 2018 11:18 pm
:lol: :lol: :lol: anti gravity 8) I'll have some of that, 3 bags should do for now :lol: I'm surprised you had time to do anything, isn't it time for a Rocky training montage before the big run :P N
ned
Postby loot » Mon Apr 16, 2018 7:37 am
Did 10 miles yesterday, I'm tapering now so lots of rest and carb loading :D
Ids map here
loot
Postby loot » Mon Apr 16, 2018 6:07 pm
Bit more erberfitting. Although it's a Chinese clone by planar or something.
Ids map here
loot
Postby bigjohnthomas » Mon Apr 16, 2018 7:51 pm
Air filter underneath :?:
Looks a bit wee?
Almost too wee :o
bigjohnthomas
Postby loot » Mon Apr 16, 2018 9:18 pm
There's 2 pipes, intake and exhaust there's nowhere else to put them Lol i spaced them 500 apart even though i have no instructions :roll:
Hopefully be ok :D
Ids map here
loot
Postby bigjohnthomas » Mon Apr 16, 2018 10:49 pm
That's what killed my d5 sucking dog hairs in ,not enough fresh air making it smoke clogging up with carbon and burning heater plugs out
Looks good though have you cracked it up yet? :P
bigjohnthomas
Postby loot » Mon Apr 16, 2018 11:36 pm
No i still have to do the fuel and wiring.
On my custom i have this pump by the fuel filter.
Which looks the same as my heater one
Which in theory i could just T into and connect the connector so it powers the van pump to fuel the heater, they both won't be on at the same time.
Not actually sure what the van 1 is for yet? Is it a lift pump to help the main pump? Is it the only pump? Bit poxy if it is Lol. Do you have 1 on billy? Maybe mine is for the hilti?
Ids map here
loot
Postby bigjohnthomas » Tue Apr 17, 2018 6:55 am
Doesn't that pump control how much heat comes out of the heater?
On startup and low mine would go tick. Tick. Tick. Tick
Then on full bor it went ticktockticktockticktock :?
I had a separate tank full of red for mine it used to use 5 gallons a month
bigjohnthomas
Postby loot » Tue Apr 17, 2018 9:46 am
Yes it is the fuel Kettering pump, if it tics then it'll be a solenoid actuated type like electronic version of the old cam shaft mechanical fuel pumps you had :o
There's 1 on the van already though does billy have 1 please?
Ids map here
loot
Postby bigjohnthomas » Tue Apr 17, 2018 10:00 am
Oh no do I have to crawl under that muddy van again :(
Where is it near the fuel filter?
bigjohnthomas
Postby loot » Tue Apr 17, 2018 10:14 am
Yes in the middle connected to the front sub frame, you can see it just by having a quick look, no crawling or anything necessary :wink:
Also that faulty mirror needs replacing because it doesn't show the correct image when you put the van in reverse there's different coloured lines etc but I'll happily buy it off you spare or repair :o
Ids map here
loot
Postby bigjohnthomas » Tue Apr 17, 2018 10:46 am
Is that it?
bigjohnthomas
Postby bigjohnthomas » Tue Apr 17, 2018 11:04 am
Mines a bit bloody rusty down below
Have to get some red lead and stone chip out when it dries up a bit
Have you started that heater up yet ? :P
bigjohnthomas
