Loots Red custom
Re: Loots Red custom
Postby loot » Sat Sep 29, 2018 3:58 pm
No, the last 1 wasn't, this 1 was all floppy inside anyway, there's washer rings that you can swivel around and they change the angle of it as they are wavy :D
Ids map here
loot
Postby ned » Sat Sep 29, 2018 5:39 pm
Ah so just shoddy chineseses sweat shop work :wink: some 12 year old will be sacked for that and not get his 12p a year :lol:
Is it fitted yet :mrgreen:
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Altransit » Sat Sep 29, 2018 7:51 pm
loot wrote:I was getting annoyed with having to double press the fob to reset the mirrors. Not road tested but I can open doors and mirrors, close doors and mirrors stay then open doors and mirrors stay then double lock doors and mirrors close. Happy with that 8)
I expect with you having yours set on single lock to close and single open to unfold, it all works fine? :P I was so close to removing the whole lot today :?
Have you mastered opening/closing of the windows with the fob yet :?: :wink: :P :mrgreen:
Postby loot » Sat Sep 29, 2018 8:14 pm
The module is all there and works for locking the windows with the fob but I haven't wired up the trigger yet :mrgreen:
Ids map here
loot
Postby loot » Fri Nov 16, 2018 7:04 pm
Bloody thing, it is leaking pas fluid from the lower pipe that goes into the rack, can I seal them or is it new o ring? Only done 18k and it was probably leaking at the service which they never saw :roll:
Was thinking of Aralditing the bugger :lol:
Ids map here
loot
Postby loot » Sat Nov 17, 2018 6:37 pm
Spent most of the day being lazy because I have a very heavy trolley jack and axle stand in the garage and knew I'd have to invest in hauling it out to the main road to use it in order to be able to get under the van, anyway I finally plucked up enough come the fook on to attempt it.
So the plan, fix the drip coming from the steering rack pipe union, :? 18k miles you think it would be OK :roll:
And refit my extra pulley on the crank that powers the 3rd belt aux for 2nd alt and the powerall system.
It was catching the inner wing so I had it put on a large to remove the outer face and I bought a v rib belt that had 1 less v and that would give me more room between the engine and inner wing, the sound it made haunted me lol.
So I found 2 o rings which was part of the space heater kit would you believe :shock: that slotted over both pass pipes and sealed them. 8)
And the pulley is on and not jumping over or anything. I'm made up really 8) next job, tow bar wiring. Could still do with loots lair though :?
Ids map here
loot
Postby bigjohnthomas » Sat Nov 17, 2018 9:25 pm
O ring gave up ?
Bloody ford
I would be dipping my foul pen in poison and writing a strongly worded letter to the Hevea brasiliensis post haste :x
For it is the root of all that is evil
bigjohnthomas
Postby loot » Sat Nov 17, 2018 9:32 pm
The original o rings look ok, they're stiff I think nylon green. There's a flange where it locates in the hole and I found 2 rubber o rings that went to this and got squashed when I pushed the pipes in, for power steering pipes I guess the pressure isn't much but I still think that it is inadequate :x
Bloody Ford.
Ids map here
loot
Postby bigjohnthomas » Sat Nov 17, 2018 9:51 pm
you need to put some miles on it
things don't like not being used much :lol:
is that tow bar sorted yet 13 pin plug :?:
mr spunker strikes again :|
bigjohnthomas
Postby loot » Sat Nov 17, 2018 10:29 pm
bigjohnthomas wrote:you need to put some miles on it
Tow bar is fitted electrics are next, have a dash cam that needs wiring in too, it has front and rear cameras :shock:
Also need to finish the heater timer and the 240 inverter.
Then camperize it :mrgreen:
Ids map here
loot
Postby Cider Andy » Sun Nov 18, 2018 7:40 pm
loot wrote:... refit my extra pulley on the crank that powers the 3rd belt aux for 2nd alt...
Did it have that set-up when you bought it? Mine has something similar: an extra crankshaft pulley but driving a second aircon compressor. As I've a spare alternator I did consider mounting that in place of the compressor, on the same bracket.
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Postby loot » Sun Nov 18, 2018 9:56 pm
Mine has the powerall system as it was a Hilti van.
It also has Aircon so i have a big belt and a little belt on the double crank pulley but then there's another pulley that has the extra non standard belt for the extra alternator. Which powers the powerall box which adjusts power and revs to the inverter 240v and the 110v site output.
You can probably buy the brackets from powerall for the extra alternator, I enquired about replacing my pulley and they wanted 150 quid :shock:
Ids map here
loot
Postby loot » Fri Dec 07, 2018 2:21 pm
Got the ids thingamabob out and cleared a few parameters and also enabled trailer module 13pin and trailer tow socket. Not installed it yet lol and have bulb failure dtc but the lights still work. :o
Ids map here
loot
Postby loot » Sun Dec 09, 2018 11:59 pm
My van was registered on December 17th 2015 so when do I Mot it? :shock:
Tax tends to be a day earlier that 12 months doesn't it so so I assume I do it 3 days earlier or is it 2 or just the same date as registration.
Could end up with multiple speeding fines here plus no mot which means no insurance so now I'm a big time criminal and looking at 5 years to life in prison :shock:
Be in tv and in news papers :shock:
Some serious sh*t about to go down here chaps. :oops:
Ids map here
loot
Postby bigjohnthomas » Mon Dec 10, 2018 12:15 am
Upto a Month before it's 3 years old and it will get 12 months from your reg date init ?
Don't know what your doing with a 3 year old van
Are you becoming a tramp ?
bigjohnthomas
