Loots Red custom
Re: Loots Red custom
Postby loot » Mon Dec 10, 2018 9:34 am
Yes and the neighbours have started to shun me when I pass them in the street, :( no more tipping of hats and invites to house parties. They showed me what would happen if I continue down this path, oh it was very unpleasant, it was another neighbour with a slightly older van and they stripped him naked and covered him in tar and fathers then they walked him out of the street and I've not seen him since :shock:
His van got sent to the wreckers and there's a new family living in his house with an 18 reg ducato :shock: bit of a sideways step like :lol:
Might get a private reg plate and upgrade the front bumper. :P
Ids map here
loot
Postby loot » Thu Dec 13, 2018 4:18 pm
Just bought 2 power steering pipe o ring seals and a pass pump pulley all delivered for just under 50 quid.
And I still have 4 days warranty :roll:
Ids map here
loot
Postby loot » Fri Dec 14, 2018 2:32 pm
Got my power steering 'kit' which is seals, 1 green and I have 3 or 4 other seals, i looked on catcar and it only shows where 2 of the seals go, which is the 2 pipes going into the rack :roll:
Ids map here
loot
Postby loot » Fri Dec 14, 2018 4:47 pm
Right so I had 3 black and 1 green, on the van there's 2 black on 1 pipe and 1 blue on the other :roll: the green is bigger than the blue a bit and when I fit it I can't fit the pipe because the o ring squashes down the side, next is another black that sits the same as the blue did, fitted all that and used instant gasket but it is still dripping ffs
Ids map here
loot
Postby ned » Fri Dec 14, 2018 5:58 pm
Bloody van, I blame brexit or teresass may :lol:
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Fri Dec 14, 2018 6:40 pm
Not a good day :(
Window tomorrow and mot Monday, mot rules.
Oil leak minor
Oil drip major
:lol: :roll:
Erm it is a leak that eventually turns into a drip in accordance with the laws of physics, so its a minor danger then?.
Warranty runs out on Tuesday :x
Fancy leaving it all to the last minute eh.
Ids map here
loot
Postby ned » Fri Dec 14, 2018 6:50 pm
Stick a bit of duct tape over the leaking drip :wink: why's a 3 year old van leaking/dripping vital fluids?
ned
Postby loot » Fri Dec 14, 2018 6:53 pm
The pipes just have tiny o rings on then and they push into the rack then a plate holds them in with a bolt. They are loose ish fit and not compression, they've given me the wrong or useless seals. I even put instant gasket on it :roll: it isn't high pressure I don't think but w*** of a job :?
Might buy a new pipe, £50 ebay.
Ids map here
loot
Postby ned » Fri Dec 14, 2018 6:57 pm
Ah rightyho I get it now :oops: its pas fluid innit, would fitting a different O ring work? I have a box of assorted size O rings, never bloody used one yet :lol:
3 years old is like 21 in van years isn't it :?
ned
Postby loot » Fri Dec 14, 2018 7:07 pm
Needs scrapping :lol:
Ids map here
loot
Postby Altransit » Sat Dec 15, 2018 12:24 am
No leaks from anywhere on my trampy 10 year old Mk7...................
...............just saying like :P :lol:
Postby andz327 » Sat Dec 15, 2018 12:49 am
loot wrote:Right so I had 3 black and 1 green, on the van there's 2 black on 1 pipe and 1 blue on the other :roll: the green is bigger than the blue a bit and when I fit it I can't fit the pipe because the o ring squashes down the side, next is another black that sits the same as the blue did, fitted all that and used instant gasket but it is still dripping ffs
Instant gasket that's desparado stuffffff is this loot an imposter , where's the real Loot ????? What have ye done with him ????
ANDZ
andz327
Postby loot » Sat Dec 15, 2018 8:31 am
Unfortunately a brand new o ring and a clean up didn't cut the mustard so i took the extreme measure of giving it some help.
Also hasn't worked, it's like the o ring isn't big enough to bridge the gap.
Bloody Ford :(
See Al fwd are crap, my 07 mk7 probably doesn't have all these problems either :P
Ids map here
loot
Postby loot » Sat Dec 15, 2018 10:01 am
So I drove to work to meet not 1 but 2 high roof customs, I asked if I can open the factory then move the wagon out then back my van in then they drove their van in, was cold and windy out see.
Did all that and the guy said, wrong window mate sorry :?
They have to get Ford glass due to me having the front camera.
Next Friday it is then
Mot is on Monday and warranty runs out on Tuesday.
Ids map here
loot
Postby bigjohnthomas » Sat Dec 15, 2018 10:16 am
Bloody winkers
bigjohnthomas
