TheDrunks - Ex-BT Van project
Postby TheDrunk » Tue Jun 26, 2007 9:35 pm
it only lost a small amount though,,?
Crazy BT van man.
TheDrunk
Postby MrMPuk » Tue Jun 26, 2007 9:36 pm
TheDrunk wrote:it only lost a small amount though,,?
If it's enough for you to be worrying about distilled water then it is to much.
Postby gemini » Tue Jun 26, 2007 9:37 pm
TheDrunk wrote:Started the van up and happily it started first time. :) However the battery low light stays on, even after I left the engine ticking over for 5 mins.
wont go off till you rev it
gemini
Postby TheDrunk » Tue Jun 26, 2007 9:53 pm
mrmpuk:
It wasn't enough to be worrying about it. I bought the distilled water because I didn't know how bad it was.
When I opened the caps, the plates (which is all that is supposed to be covered) were covered. I believe all that had escaped was excess.
I am pretty sure that once the battery is fully charged (after it is next driven) it will be fine. Afterall, I did get it to start the engine three times in a row.
Crazy BT van man.
TheDrunk
Postby djswampy » Tue Jun 26, 2007 9:56 pm
Keep the receipt and write on the top the date of fitment. you should get 12 months warrantee (terms and conditions etc).
djswampy
Postby TheDrunk » Tue Jun 26, 2007 10:13 pm
OK the OIL thread
FORUMS:
2.5 DI
(not recommended but listed as an alternative)
SAE 10W40 - ACEA A3-96/B3-96 or API SH/CD EC
HAYNES:
SAE 10W/30 to API SH/CD, ACEA A2-96 AND B2-96 OR TO ACEA A3-96 AND B3-96
OWNERS MANUAL:
API-SG/CD
SAE 10W-30
(does mention 10W-40 on the chart in the manual though)
OIL I HAVE PURCHASED:
Castrol GTX Diesel 10W40 4 Litre
itemcode: 919019-0
SAE 10W-40
ACEA A3/B3
API CF
MB 229.1
VW 505.00
http://www.ew2.lubesinfo.com/frameset.a ... 6&langid=1
The alternative one they recommend for this engine.
Anyone recommend a good guide or can explain what all the different variables mean? Specifically
API
ACEA
SAE
It is the API which differs between the oil I have and the recommended.
Thanks.
Crazy BT van man.
TheDrunk
Postby gemini » Tue Jun 26, 2007 11:26 pm
gemini
Postby TheDrunk » Tue Jun 26, 2007 11:53 pm
Crazy BT van man.
TheDrunk
Postby TheDrunk » Thu Jun 28, 2007 1:29 pm
How the heck do you tell if you have 14 or 15" wheels? Just measure them, or is there a marking on the rims / other?
Reason I ask is, it isn't easy for me to get to the van, so if I can tell from a photo...
TIA :)
Crazy BT van man.
TheDrunk
Postby sportscott » Thu Jun 28, 2007 4:41 pm
TheDrunk wrote:How the heck do you tell if you have 14 or 15" wheels? Just measure them, or is there a marking on the rims / other?
TIA :)
I think if you have standard wheels they will be 14 inch :lol:
Transit the everyday mans van....
sportscott
Postby dangeeeeerousss » Thu Jun 28, 2007 4:49 pm
yes i have a 94 transit sat on standard rims and there 14's
dangeeeeerousss
Postby captain hook » Thu Jun 28, 2007 5:06 pm
Are there no motor factors in West Yorkshire???
Why buy from the 'net and trust Couriers???
I know 'coz I used to be one.... :P
captain hook
Postby TheDrunk » Thu Jun 28, 2007 9:16 pm
The Motor factors is in West Yorkshire. I just didn't have the time to go over and get the stuff....
Anyway progress:
Dropped the van off with a garage this evening.
360quid for the rear cross-member and front arches, front disc brakes, pads, brake pipes, track rod ends, roll bar, and MOT.
I think thats a bloody good price considering the other guy wanted 350+ just to weld the back...
Should get an MOT'd van back in about a week. 8)
Crazy BT van man.
TheDrunk
Postby djswampy » Thu Jun 28, 2007 9:39 pm
Good luck. You'll need it :P
djswampy
Postby TheDrunk » Fri Jun 29, 2007 9:13 am
What sort of price would you pay for:
New timing belt
New fan belt
New complete exaust
installed.
Don't fancy doing the timing belt myself...
Crazy BT van man.
TheDrunk
