One of the front - ignore the pipes been neatened now
close up on the engine
and one of the pipe
apart from that it's a pritty standard looking van
rover wrote:I assume the valve you are on about was a dump valve of some variety? If it had one before then it probably needs one.
ive got it connected to the plenum after the throttle butterfly - it seems to be working although its not got a 1 way valve in the line i'm assuming its actually in the servo as it seems to work ok and hold the vacuum even when the turbo is boostingrover wrote:How is the servo connected? The servo works from negative manifold pressure but the turbo creates positive manifold pressure so there is no vacum to activate the servo![]()
neat idearover wrote:The intercooler pipes will blow off quite easily without a lip on them, the easiest way to create one is with a cable tie cut to length and bonded in place with epoxy resin, used to do this a lot on Montego/Maestro turbo conversions![]()
transitgeoff wrote:looks quite easy to lower the rear an inch or 2
that means a lot to me matecoconut wrote:its the only petrol mk6 i would want to own
