by Chaz&Saz » Fri Sep 18, 2009 4:43 pm
A little more progress, I have just taken out the front seats, floor mat, glove box and heater to look at the bulkhead and get ready for welding, There is a little more to do than i thought but on the scale of things its ok. After stripping the engine back to a bare block i decided that it was not cost effective to repair so i brought a short motor of the bay in need of a rebuild, It already had been re-bored and had a low milage set of pistons already fitted, I am treating this to a new set of rings, shells, core plugs, the crank needed a grind so that has now been done i have a new cam and followers ready for it, Have a pair of heads ready for a rebuild. so between the left over 2.5 parts the engine will soon be ready to go.
Sarah has started pulliing the insides out and designing a new look,
I am of two minds on fitting a Mk3 front axle. It would be good to have disk brakes but my efforts would be better spent on other areas of the van and speaking to people that drive Mk1 transits they have said the drums are fine so might leave that as a upgrade once back on the road. Hopefully post some pics soon.
Charlie
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
