Thanks for all the 'positives' people, happy to offer advice or even carry out repairs for you lot.
That is the great thing about this Forum, help is only a 'post' away
Right then, some more pics of the progress made during the last week;
We have now fitted the N/s rear inner wheel arch, as can be seen from my previous post, the part needs a small amount of alteration to enable fitment, it started out like this;
The old outer wheel arch was removed and the replacement outer arch positioned behind the outer wing panel and secured in place with self tapping screws, the remnants of the inner arch were used to assist in achieving correct positioning of the outer arch, much the same process was used on the O/s, see earlier in the thread.
The new outer arch repair panel was then removed, the locating holes remain in the rear wing panel, these will provide accurate alignment when we come to replace the outer arch;
If you look carefully, you can just see the small holes in the rear wing.
Now we removed the inner arch;
Not too difficult a job, good access if available inside the van once any interior trim or ply lining is removed.
The replacement inner arch was pushed into place from below the vehicle, a small amount of 'fiddling' is required at this point, there is an internal support at the top of the arch that may need pushing out of the way;
You can see the alignment holes for the outer arch in the above pictures.
Next the outer arch panel was pushed into place, the screws were replaced securing the outer arch to the outer wing.
The outer and inner arches were then fixed together with screws, this all serves to ensure that both panels are aligned correctly;
Now we are ready to weld the inner arch to the vehicle, where the panel overlaps the original structure of the van, spot welding was employed, but 'plunge welding' with the mig would be satisfactory;
You can see one of the crews used to temporarily secure the inner arch panel.
Once the inner arch has been welded to the flange inside the van and we know that it is unable to move and loose alignment, the outer arch panel can again be 'unscrewed', this allows us to weld the support at the rear of the arch at 'floor' level;
The outer arch panel is finally fitted once more, this being spot welded to the inner arch panel at the 'arch lip';
we remove the screws as we weld so as to ensure that the two panels remain in close contact.
All that remains to be done now is weld the outer arch to the rear wing, small areas at a time to minimise distortion, and 'fill to perfection'
