Rover V8 to Transit MT75 Gearbox Adapter
Re: Rover V8 to Transit MT75 Gearbox Adapter
Postby dieselhead123 » Fri Nov 01, 2013 10:19 pm
As promiced, some pictures of the 'mocked up' engine mountings, L/H;
R/H;
The card patterns were cut out from templates using the CAD files so are pretty much as will be produced, the 'real' ones will be in steel though!
From the 'mock ups' we can confirm that it will be possible to remove the starter motor with the mounting in place and that all the fixings can be accessed with a socket.
Postby limitedblack » Sat Nov 02, 2013 11:55 am
Don't let ford see that Tim, they'll start making parts out of paper too, oh sorry we're too late apparently.
Happy Easter
limitedblack
Postby robbie.cee » Sun Nov 03, 2013 9:43 am
Mate that's awesome! More.top work there ! V8 power... Nice!
What's the.coup re Flywheel, rover flywheels are well chunky will you use rover or ford Flywheel?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Keef » Sun Nov 03, 2013 12:26 pm
Wouldn't it be stronger it the square section was extended to go over the Transit mount fixings?
With the angled ends, you could still easily get to the nuts.
Keef
Postby dieselhead123 » Sun Nov 03, 2013 3:05 pm
robbie.cee wrote:Mate that's awesome! More.top work there ! V8 power... Nice!
Hi Robbie, simplest solution is to use the RV8 flywheel, the Land/Range Rover ones are easily obtainable and accept the larger heavy duty Transit clutch, also use the standard RV8 starter motor that way.
Postby dieselhead123 » Sun Nov 03, 2013 3:11 pm
max.print wrote:Wouldn't it be stronger it the square section was extended to go over the Transit mount fixings?
You are correct there mate, the 'box section' part of the mount is open to re-design, I would much prefere it to extend to over the Transit mounting, simmilar to the way we did the V6 Essex ones.
The box sections in the pics were 'rescued' from the scrap bin, but were sufficient to confirm access and fit.
When they are manufactured properly, with longer sections, you are welcome to take credit for the design improvement :D
Your commission is in the post :lol:
Stay safe mate
Postby thegreathowardo » Mon Nov 18, 2013 6:43 pm
Hi, How soon will this adaptor plate and spigot be available? I am just about to start my next V8 conversion on a smiley Luton, already V8-ed a '91 Recovery Transit. Does it use the standard V8 flywheel redrilled to take the Transit clutch? Thanks!
thegreathowardo
Postby dieselhead123 » Tue Nov 19, 2013 7:12 pm
thegreathowardo wrote:Hi, How soon will this adaptor plate and spigot be available? I am just about to start my next V8 conversion on a smiley Luton, already V8-ed a '91 Recovery Transit. Does it use the standard V8 flywheel redrilled to take the Transit clutch? Thanks!
The conversion uses the standard V8 clutch and flywheel.
The larger clutch used on the 4x4 V8s is the same one as the heavy duty one fitted to the Di powered Transits.
Our recomendation is to use the 4x4 flywheel and clutch assembly with the standard Mt75 release bearing.
The adapter plates have been developed, a sample has been produced, see earlier in the thread.
The spigot bearings have been selected and I expect a delivery of these later this week.
All that remains is for us to assemble a 'batch' of engine mountings.
The parts to connect the engine to the gearbox, including all fixings, will be priced at £175, the same as our Essex 'kit'.
The pricing of the engine mountings and power steering adapter parts will not be 'confirmed' untill these parts have beed assembled.
How soon are you likely to 'move forward' mate?
Postby thegreathowardo » Fri Nov 22, 2013 12:12 pm
As soon as possible, I actually collected a 5 speed LT77 box yesterday but am keen to try the conversion with the Transit box. We are moving to France and after one trip in the diesel luton I am going to cut the travelling time down and the only way to do that is with a V8!!! I'll only need the adaptor plate and spigot bearing to start with, having already done a recovery truck with a V8 and P6 gearbox this should be a breeze! I'll cobble my own engine mounts. I am only down near Dover so may pop up for a chat next week? Cheers, Howard
thegreathowardo
Postby thegreathowardo » Sat Nov 23, 2013 12:43 pm
The V8 equipped recovery truck
thegreathowardo
Postby dieselhead123 » Sat Nov 23, 2013 3:04 pm
Nice job there mate 8)
Just give me a call on the works number, 07754 806004 and we will arrange a date.
Be good to chat with you about some of the ancillary fitmants on the RV8
Postby blue estate » Sat Nov 23, 2013 3:57 pm
limitedblack wrote:Will it fit my mk7 Tim ? :lol:
The developmemnt is intended to work with the Mk6/7 Mt75 as well, but only the RWD ones :lol:
:D a rover v8 powered jumbo mmm
blue estate
Postby thegreathowardo » Sat Nov 23, 2013 4:04 pm
The incredible gearchange mechanism for the Rover P6 gearbox to Transit fitment... but it works. Engine and gearbox were centralised in the chassis (Transit crank is off centre) so as to make the bulkhead mods easier, hence the off centre gearlever. The gear lever was lengthened as was the portion underneath the 'ball' to get the throw at the top of the gearlever to an acceptable level. The down side with this conversion is the P6 4 speed gearbox only has a 1:1 top gear... this gives 18mph per 1000 rpm with the 4.63:1 rear axle.
thegreathowardo
Postby dieselhead123 » Sun Dec 29, 2013 9:23 pm
thegreathowardo wrote:Image
Hi there, hope you had a good Christmas :D
It was good to chat for a while when you visited the workshop, great to chat with you about your conversion.
The adapter plate has been ordered and will be available mid January together with the spigot assembly.
I will contact you once it is allready mate.
In the meantime, stay safe, and have a good new year.
Postby badger the welder » Sun Dec 29, 2013 9:47 pm
This is what you want under the bonnet :twisted:
badger the welder
