My '96 150 Custom LWB High Top
Re: My '96 150 Custom LWB High Top
Postby MinorMatt » Mon Aug 04, 2014 6:25 pm
She doesn't weld as well as me... but is much much much better at shaping the metal, attaching it in the right place and filling!
We both have slightly different - but complementary skills which helps a lot!
Postby kalkat » Mon Aug 11, 2014 8:32 pm
Right then, after doing some more on the van, finding my camera lead (eventually) and working out the latest 'improved' Photobucket - here's an update :D
We start here just after tacking in the new inner arch panel so's to have some idea as to where all the other new bits go.
The first bit I wanted to survey was a hole through the return in the rear of the arch......
...... well I thought, seeing as the outer bit of the arch was poo .......
...... chop it off :twisted: However this had the unfortunate result of showing even more rust, sooooooooo...........
........... I cut that out too!
At last - *fanfare* NEW METAL* ........
And ..................
There are a few more repairs I've not shown, mostly due to forgetting to photo them (or sucking burnt fingers) and the eagle eyed will notice I've recycled the sill outer although it has a new underside. Also in the pic, it's still to receive a patch in the top.
Tata for now .... I'm off to go and hit summat else :lol:
.......... hitting things since I was old enough to hold a hammer
kalkat
Location: Wodering if everything in the farm building has rusted solid yet?
Postby MinorMatt » Mon Aug 11, 2014 9:32 pm
Everyone should have a KalKat 8)
Postby RustWidow » Mon Aug 11, 2014 10:23 pm
Lol Matt, good job though. But don't you find that rust has that awful habit of sneaking up on you just as you think you've found the last of it?
RustWidow
Postby kalkat » Tue Aug 12, 2014 11:51 am
i have a small hammer that I use to 'tap' small areas that are suspect................. it's often 'quite interesting' just how many times it goes through!
kalkat
Postby MinorMatt » Sat Aug 16, 2014 9:16 pm
More work has happened....
I think it may be best if pics show whats happened? Nothing unexpected... except the strut tops are perfect 8)
Previous step repair was just a nicely welded piece of metal over the rot...
so choppy choppy weldy weldy
(one more pic when it uploads, and probably more tomorrow!)
Postby MinorMatt » Sat Aug 16, 2014 9:41 pm
Kalkat shaping the metal... me welding it in!
Postby RustWidow » Sat Aug 16, 2014 10:00 pm
Nice job you two
RustWidow
Postby Reading Fan » Sun Aug 24, 2014 8:52 am
Looking good there Matt, nice to see it slowly coming together, so glad I never attempted to do any work, though if I had Kitkat I could have been tempted, coffee and biscuits for fuel I assume.
Away from the tranny now, picked up 54 reg Sprinter 4m yesterday, bodywork sweet as a nut, at first glance.
Reading Fan
Postby kalkat » Sun Aug 24, 2014 3:21 pm
Fuel... TEA ......and cakes, chocolate, doughnuts,battenburg, pot noodles ....... you get the idea :wink:
..... oh - and I EAT Kitkats.....
kalkat
Postby kalkat » Sun Aug 24, 2014 3:52 pm
....... oops! sorry RW, I forgot - fank'oo
kalkat
Postby RustWidow » Sun Aug 24, 2014 4:33 pm
No probs kalkat, but it is awesome work
RustWidow
Postby MinorMatt » Tue Aug 26, 2014 12:54 pm
Grr having problems - lots of pics but this computer is playing up!
Kalkat might post them up from mmy photobucket though
In the mean time... it went to Billing (you can also see the purchase I made for it!)
Postby ake » Tue Aug 26, 2014 1:34 pm
MinorMatt wrote:Grr having problems - lots of pics but this computer is playing up!
The awning definately suits your van better than it suited mine 8)
Postby MinorMatt » Wed Aug 27, 2014 7:57 am
Lets see if I can get this post sorted today...
Those of you who were at Billing might have noticed the van has progressed a bit from the pics posted so far...
I got on with doing the repairs to the inner sill and outriggers around the passenger side rear arch (but didn't take any pics :evil: ) whilst Kalkat got on with the temporary repair to the passenger arch (fibreglass & filler!)and finished tidying up the divers arch & step
Once I had done the welding underneath (well all that I could be bothered to do...) I painted up the drivers side inner arch with cold galvanising spray, and then chassis black
And I then moved on to the rusty patch which offended me most on the van - a hole in the B post above the fuel filler apature.
I gave the van a bit of a wash (with a plastic scouring pad!!!) - This photo shows the difference!
We then got everything masked up and put a coat of primer and then blue on... in the dark, and it rained in the night too :lol:
Kalkat rubbed back the runs, and we both poloshed it up with the buffer and a bit of G10.
I also fitted headlamp protectors, a glass headlight to replace the degraded plastic one and a few other bits too (ply lining etc)
