kxrf wrote:Trannygrandad wrote:kxrf wrote:DId you mount the Unwin track with through bolts and backup plates?
I have some thoughts of installing some two-position track on some of the side pillars - back of which are blind and was considering something like this:
http://rivetsonline.com/rivet-nuts-and- ... eries.html
Thoughts?
frank
what do you intending anchoring in the tracks, if it is for disability wheelchairs/scooters
I think your insurers would be uncomfortable if it were not an industry standard procedure that had been crash tested. I keep coming up against a brick wall when I ask for non standard fitting/ adaptation in the trade.
My intention is a cargo net that can be placed either directly behind the rear seats, retaining seating for five, or moving the net just behind the tumbled second row seats. Something like this ( http://www.uscargocontrol.com/Van-Trail ... /Cargo-Net ).
I would mount these ( http://www.uscargocontrol.com/Ratchet-S ... ck-2-Piece) along the internal bracing along the sides, top, and floor to anchor the net. As those bracing "arches" are formed in a basic "U" shape, then the skin welded to it, the backside of those braces would be inaccessible to attach a traditional fastener - sheet metal screws would be wholly inadequate, but the blind threaded rivets, in theory, would work well.
Certainly, a net mounted like this would be superior to the built-in netting supplied in my BMW 5-series wagon, and far better than nothing at all.
In the US, cargo/passenger separation laws seems much more lax than in UK/Europe. Nearly all cargo vans here are sold without any bulkhead at all. Airport shuttle vans also have no separation between luggage and passengers. I understand, depending on the cargo laws of the locality or country, why an insurer would be unsure of approving anything not tested and certified. Part of my problem is finding anything designed to fit behind the second row of seats on my 2013.
frank
Interestingly, I have used those SS Rings mounted directly to unwin track floor & sidewall to fit a cargo net from my old Peugeot 306 before I scrapped it
