intransit67 hi-cube up date!!!!bit of try of the 2k white
Postby chadmat » Sat Sep 22, 2007 11:08 pm
Cool looking van mate!
In a MK6 280 SWB semi hi!!!!
There you go! At last!
chadmat
Postby intransit89 » Sat Sep 22, 2007 11:16 pm
chadmat wrote:Cool looking van mate!
was omega blue but it look old and faded so a new colour respray makes it look cool :wink:
intransit89
Postby AndyG » Sat Sep 22, 2007 11:21 pm
It should have been Diamond white mate :!: :shock: Can't see it now :!: :lol:
Just kiddin' :!: :lol: :lol: :lol: :wink:
It's looking good 8) 8)
Are you doing the door shuts :?:
Postby intransit89 » Sat Sep 22, 2007 11:30 pm
Andyg wrote:It should have been Diamond white mate :!: :shock: Can't see it now :!: :lol:
you mean the inside yes when i get some more thinners ran out and got about 4L paint left :x
intransit89
Postby intransit89 » Tue Sep 25, 2007 2:04 am
in the day light
intransit89
Postby dangeeeeerousss » Tue Sep 25, 2007 4:03 am
motorwise wrote:
dangeeeeerousss wrote:seriously the car was stolen 6 yrs ago ill double check the reg but im 99.9% sure thats 1 mate if it is ill have to ring the old bill
possibly is yours - recovered by the insurance company and then sold on via auction - once you've claimed the money you have no more interest in it and it's theirs to sell
hi motorwise
i was just trying to bend his head a bit :twisted: i was winding him up because he'd done my head in that night :lol:
had him worried for a bit lol
dangeeeeerousss
Postby intransit89 » Tue Sep 25, 2007 4:21 am
hi motorwise
wasnt funny till i said about the seats beeing cloth lol and being digital clock lol and then know it was a gsi lol :lol: :? :lol:
intransit89
Postby chadmat » Tue Sep 25, 2007 9:43 pm
intransit89 wrote:in the day light
Looks proper cool Now!!!
chadmat
Postby intransit89 » Wed Sep 26, 2007 2:31 am
havnt finshed yet ! :D
intransit89
Re: intransit67 hi-cube up date!!!!!!!!
Postby intransit89 » Mon Jun 30, 2008 2:46 am
up date on this its having the front drivers side wing sorted cut from a mk4 for the arch only :!:
drivers side sill
back pass side quoter
and bottom panel below the drivers side back sliding door would be
but 1st job is a new pass side spring as its snaped :!: could explain the right hand corners are crap nerly rolls over will get pic this week of the snaped spring :shock: orded a new one
then a rub down all over and them gray primer and its being 2k diamond white with the blue stripes at back in 3 shades of blue and some castrol decels on bottom of the front doors
and a colin mcrae sig on the back doors 8)
heres the photo shop of what i did for dave :D
viewtopic.php?f=30&t=29083
intransit89
Re: intransit67 hi-cube up date!!!!!!!!the gear box pics
Postby intransit89 » Sun Jul 06, 2008 4:15 am
some gear box pics
what we done so far tock the gear leave of with the t40 x3 bolts that that sorted
starter motor removed
two gear box nuts removed still 2 in for holding it up for now
all nuts removed from gear box
prop shaft bolts removed using a t55 :wink:
there is the pics so far
:wink:
uncle be along in a bit to ask about fly wheels etc :!:
intransit89
Postby intransit67 » Sun Jul 06, 2008 6:45 am
Right time for a question.
I appear to have a heavy duty clutch as it was an ex Omega Special Order Vehicle used for parcel delivery this was told to me by a guy on ebay who sells the clutches for £45 odd quid when i phoned to ask if it would fit my van.
The heavy duty is £160.
Stamped on the cluth cover is TYP MF265 i have been told this is because the clutch is 10.5" rather than 9.5" as standard.
Would I be better off swapping the flywheel for the standard size and using the cheaper smaller clutch?
That is if I can get the box off as it is stuck probably because the 2 access rubbers were missing so allowing water and then rust to get a hold on the clutch parts.
I wish i'd left it alone now as I only wanted to sort out the knackered quadrant adjuster that was replaced and when the clutch was tried I got a noise from the bell housing and the release arm fell off or rather the bearing came off the arm.
The bearing as a clip missing on the back now so it's got to come out and have a replacement clutch.
I have had it 6 years now so it need one I suppose.
Dave
intransit67
Postby Ford Sprung Van Tastik!! » Sun Jul 06, 2008 10:44 am
Hi Dave
when you get to the flywheel :) , you will find it has 2 sets of pressure plate fixing holes , one for the smaller, and one for the larger clutch, so no need for another flywheel :D
So up to you which clutch you want to fit.
Rare genuine Mk5 190 LWB 115ps Turbo Diesel Intercooled .
If you can't fix it... use a BIGGER hammer !!!
Postby Guy88 » Sun Jul 06, 2008 10:53 am
Ford Sprung Van Tastik!! wrote:Hi Dave
You sure, My MK5 only had one set :?
As for getting it off did you remember the 8mm bolt holding the dust guard on
I have done a how to aswell if you need it
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Ford Sprung Van Tastik!! » Sun Jul 06, 2008 11:11 am
Hi Guy
As far as I know if its fitted with a big clutch it should also have the standard clutch drilled holes as well.
My hi cube had this arrangement..
