MinorMatt's Camper...
Re: MinorMatt's Camper...
Postby MinorMatt » Sat Jul 08, 2023 12:42 pm
Airthies wrote:That's some effort to get a fail on more rust
Sent from my S99 using Tapatalk
Yup, I missed 3 small bits. Didn't fail on anything else though - which is a bonus!
Postby MinorMatt » Sat Jul 08, 2023 8:27 pm
Was going to weld it up today bit
A) I had to put a new spring, and wheel on the volvo - the spring broke in.to a perfect blade to slice the sidewall off :roll:
I need to move it to get where I can weld, so had to be done
B) The camper in front of that has a flat battery
C) someone came in for a diagnostic job
D) it was raining
E) I really really could not be arsed
Postby MinorMatt » Mon Jul 10, 2023 9:49 pm
Weldathon continued...
I've not done a great deal this evening leaving me with a lot to do on Thursday evening for the Friday re-test.
I am hoping to sort the 3 "real" advisories at the same time... (nip up a wheel bearing, change a propshaft and deal with play in a rear damper bush - might need nipping up, if not swap the dampers).
I swear, scouts honour, that there was no obvious rust under the drivers battery when I was poking around there - but MOT mans pokey stick said different.
I knew about the hole in the sill half way down - its not within 30cm of anything structural so should have got away with it, and the bit under the step is tiny - I just missed it.
Im going to need to replace both battery trays at some point too :(
Postby oldskooler » Sun Jul 16, 2023 12:49 am
wow,....you werent joking about the weldathon!!....but at least there wont be many problem areas left by the time your done, and you will know theres no more hidden horrors....great work...
oldskooler
Postby MinorMatt » Mon Jul 17, 2023 11:31 am
No Photos because I couldn't be bothered.
It ended up being an 11pm finish on thursday.
All welded up now, but I ran out of gas on Thursday - before I had started the bit under the battery, so an emergency run to halfords (which is nearly an hour each way) to get some flux cored wire and tips....
Its horrible stuff and I used the entire reel before the patch was finished - so I had to break out the 2nd one which I was going to keep for an emergency.
Went for retest and..... failed! Not really it was a pass.
Fixed the wheel bearing play and the play in the shock absorber bush (the bolt just needed tightening). I was going to replace the rear UJ too - but I couldn't get the old one off (even with the air chisel) with the propshaft in situ so I will have to remove it at some point.
Postby PIO » Tue Jul 18, 2023 4:04 pm
Great work Matt, great machine to have.
PIO
Postby ned » Tue Jul 18, 2023 4:43 pm
Now the fun part of welding is done the even more fun part of body work can start, it actually looks quite good in the pictures, is that a ford colour?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby MinorMatt » Thu Jul 20, 2023 11:00 am
ned wrote:Now the fun part of welding is done the even more fun part of body work can start, it actually looks quite good in the pictures, is that a ford colour?
Its BMW Stahl grey. What you can see walking around is all pretty good to be fair.
Im still knackered :lol:
