My new camper to be :)
Re: My new camper to be :)
Postby spudmab » Sat May 10, 2008 8:03 pm
thats crap,
i have had hot weather all day, so hot i had to stop my bumper and leave it for the sun to cool down,
good luck with the camper, seems like loads of use have started about the same time with the same ideas,
cheap camper/ day van,
good luck
spudmab
Postby jamface » Sun May 11, 2008 4:12 pm
What are these holes for? do they need regular access?
what does this cover?
its in the passenger footwell.
and what does this pulley do?
also in passenger footwell
and some goodies :)
got the rear just about clean with the exception of the side step - currently in the bath!
about to strip out the cab and clean up the front now :)
'95 SWB semi-high top transit camper to be, dark blue petrol :)
jamface
Postby Ucof » Sun May 11, 2008 5:47 pm
1) Those holes are used to access the rear lights so you can change the bulbs and stuff.
2) That cover covers the end of the shock absorbers. I asked that in my thread, so that how I know! :D
3) (a guess) - This tells the air blower where to blow the air (face or feet)
Your goodies look nice. I need a battery tray too :(
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
Postby jamface » Sun May 11, 2008 6:43 pm
cheers Ucof,
Thought they were for light access - I'll leave them so you can get to them in that case!
More goodies to come tomorrow with any luck then I can get everything in - hopefully have it all cleaned out by tonight.
currently got the cab in pieces on the street :) its keeping the neighbours entertained at any rate!
Jam
jamface
Postby Ucof » Sun May 11, 2008 6:45 pm
Jamface wrote:I'll leave them so you can get to them in that case!
I must object.
I cant travel to Scotland every time you need a bulb changing ;)
Ucof
Powered by Nutella
Postby jamface » Mon May 12, 2008 1:16 pm
aw thats hardly fair now is it?
more goodies arrived today but still no wiring type bits so STILL can't fasten anything together.
currently re-building the van indoors, much to the frustration of my flatmates.
Off to find some cleaning stuff for the roof and seats and dash now, well after I've mopped the cab floor mat thing anyhow.
as an aside - Just how tempting is it to keep unscrewing things all the time - I must've told myself "I don't NEED to undo this" about a 1000 times!
Pics in a little while
Jam
jamface
Postby jamface » Thu May 15, 2008 10:59 am
From dirty
To clean
The rust
clean floor mat
clean(ish) dashboard.
Guess what I forgot to clean
new toys
anyone know what this is?
roof in its new home
and something that might interest you lot - declaration of conformity
jamface
Postby Ucof » Thu May 15, 2008 11:08 am
Where is it?
I'm very jealous that you managed to get your seats out. :( The nuts on mine, I assume, have been superglued together :(
Once I get the seats out, I could then get the mat and underfloor clean.
Its looking nice though.
What will you be doing in the back?
Ucof
Powered by Nutella
Postby jamface » Thu May 15, 2008 11:25 am
Ucof - underneath the hole in the dash on the passenger side, just above the glovebox.
You could take the entire seat and rails out if you have a T35 (I think, could be T40) torx (star head) bolt - would probably be easier than the nuts.
Plans for the back involve folding bed/sofa, full insulation and space to store my bike.
jamface
Postby Ucof » Thu May 15, 2008 11:53 am
Nah, I tried the torx bit, even with a generous amount of WD40 type stuff - still wont move at all. Problem mainly is that I don't have a static torx screw driver, only a bit with a ratchet type driver. Every time I try to put some twist pressure on, the ratchet slips.
I might have to go buy one instead :(
(I'm currently working on the manual now for you too)
Ucof
Powered by Nutella
Postby jamface » Thu May 15, 2008 11:57 am
ah, a ratchet would've been REALLY useful for me - you get about 30 degrees rotation on the bolts - however they are those ones with the nylon inserts so don't come finger loose at all :( not looking forward to putting them back in!
jamface
Postby jamface » Fri May 16, 2008 12:29 am
finally got the stereo wired in - someone had done weird things to the wiring looms :S fixed at last and I didn't even electrocute meself - well yet anyway - now I've got to put the cab back together at full pelt for a weekend away :(
Jam
jamface
Postby Ucof » Fri May 16, 2008 8:44 am
Did the zip help?
Ucof
Powered by Nutella
Postby jamface » Fri May 16, 2008 9:51 am
was wondering what you meant by zip for ages then! think I need to wake up a little bit!
I've not attempted to get the dash out yet, that will be sometime next week I imagine.
cheers,
Jam
jamface
Postby jamface » Wed May 28, 2008 12:02 am
Well, not updated in a while, as I've been away at a mtb race last weekend and on holiday over bank holiday so heres what I've been upto since then:
* Rear fully cleaned out and rustproofed
* Floor cut to shape
* Rear door panels cut
* RHS lower panel cut
* LHS rear panel upper and lower cut
* sliding door + RHS upper drawn out and awaiting cutting when the neighbours wont complain!
Pictures when its all done + fitted
to be done tomorrow:
* All panels cut out and fastened in place
* Insulation
* Rear Speakers
To be done after:
* Affix and wire in leisure battery + charging
* Sort out lighting and inverter
* Alter stereo to run off 2nd battery
* Begin building bed/cupboard frames
* Foam for bed needs upholstering
* Roof in rear needs cleaning (AGAIN! - any tips for REALLY stubborn stains?)
* Patch up drivers seat
jamface
