Broken Gearbox MT75
Re: Broken Gearbox MT75
Postby lostpaul67 » Tue Jun 10, 2008 10:02 pm
expertcourier wrote:What viscosity should it be?
5w/20
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby Altransit » Tue Jun 10, 2008 10:02 pm
expertcourier wrote:Whats the capacity ?
1.25 litres
Postby expertcourier » Tue Jun 10, 2008 10:04 pm
will the gearbox be ok? is there a post about draining and filling
Thanks for all the help
P Reg LWB 190 for work and coming soon N Reg 80 SWB TD Auto!!!FOR FUN!!!!
190 LWB http://i272.photobucket.com/albums/jj179/expertcourier/DSC00087.jpg
SWB 80 New Projecthttp://i272.photobucket.com/albums/jj179/expertcourier/PHTO0010.jpg
expertcourier
Postby Altransit » Tue Jun 10, 2008 10:09 pm
expertcourier wrote:will the gearbox be ok?
Won't do it a lot of good, but I doubt it has badly damaged it :cry: get it changed ASAP
Postby Ford Sprung Van Tastik!! » Tue Jun 10, 2008 10:11 pm
Go back to the shop and see the Manager, explain what has happened and ask him what he is going to do about the wrongly supplied oil and possible damage to your gearbox
Rare genuine Mk5 190 LWB 115ps Turbo Diesel Intercooled .
If you can't fix it... use a BIGGER hammer !!!
Postby Altransit » Tue Jun 10, 2008 10:12 pm
expertcourier wrote:is there a post about draining and filling
I don't know, you could try a quick search on here :wink: there is a drain plug on the rear lower pass side of the box :D
Postby expertcourier » Wed Jun 11, 2008 4:20 pm
Hi
Drained the oil today and when it came out it looked just like baileys I was quite surprised.. so left it draining went to a different car shop and there on theshelf right in front of me mt45 so I got 2L and hoofed it home filled it up till it was coming out of the hole put the plug in.
I have not had chance to road test it yet goin out after tea I will let u no.
expertcourier
Postby Altransit » Wed Jun 11, 2008 7:03 pm
You may need to drain again, after a while, and refill with fresh MT75.
The other oil will contaminate the new stuff, because it doesn't all drain out :wink:
Postby MinorMatt » Wed Jun 11, 2008 8:33 pm
The problem is when you go to a factors that stocks comma oil the recommended oil in the book is the 75/90 for a non turbo but MT75 for a turbo!
