thats rightredeemer wrote:If I m not wrong , galvanizing is done in a hot bath, therfore better check for alligment and wrappage (heat effect of expanding or soemething)
nice work farsalvage look forward to seeing this done
farsalvage wrote:mk5 transit recovery who has built several trucks had his done at same place and far as i'm aware had no trouble... i robbed most of the design of his truck as my mate has it now.
Luke wrote:thats rightredeemer wrote:If I m not wrong , galvanizing is done in a hot bath, therfore better check for alligment and wrappage (heat effect of expanding or soemething)but i cant see a problem with this design
you'd only really have a potential problem if you had say the deck welded on out of thinner (say 3mm) flat sheet surrounded by thicker section not allowing expansion at the same rate! even then it wouldn't distort the frame but you might get minor distortion on the plates
