Thinking about it I changed alot of bits on your truck including the gearbox/ clutch etc.
Do you work for them or just know them ?.
ginsambo wrote:Almost a year and a half later and I'm back on it!![]()
Can't see there being a problem with dissembling it completely now to galvanise, as its so light, as long as I have a straight jig to reassemble it on and get it square it should be straightforward. Only problem with galvanising is that every little piece of lapped steel reinforcement has to be drilled out and dissassembled first.
Next will be the floor and rear cab panels. At least the chassis sopt welds are every two inches or more, which reduces the amount of drilling I'II have to do to about 3000 holes, rather than the 10,000 I was imagining.
alcapone wrote:I look forward to seeing pictures of the finished product
ginsambo wrote:alcapone wrote:I look forward to seeing pictures of the finished product
Hope you are patient....
Users browsing this forum: Baidu [Spider]
