The V4 and V6 Cologne engines are direct family, so I could have used the original engine mounts. As You can see from the last picture, the V4 mounts are pretty long stalks. This setup is not very stable and could cause vibrations with the heavier engine. The engine mounts and rubbers of the Scorpio are much better. This is why I decided to take the complete subframe from the Scorpio, modify it and bolt it into the MK1. The width of the subframe was almost perfect. However in the MK1 it needs to be 6 cm to the right. This is what the subframe looks like:
The yellow piece needed to be removed and the red piece needed to be added. I removed the existing brackets from the framerails, opened the seam of the rails a bit and inserted two strips of 2,5 mm metal with M12 bolts welded to it. After that I welded the seams and the subframe could be bolted in. Like this:
