Long time between updates, but not much happening to the truck...
The place I got the gearbox from sent me the wrong belhousing with it, for th later OHC motor, and it has taken them until now (over 3 months!!!) to find the right one and finally send it to me...after a couple of dozen phone calls which they never respond to, even now I am waiting for a return call to give me the tracking number so I can check the progress of the bellhousing...
Annoyed doesn't even begin to describe it...
So, the truck has been sitting in my shed with no gearbox, but it is about to go back together again!
About bloody time too!
Anyhow, I have taken some more pictures and uploaded some more to photobucket, so I can update this thread a little...
This is the damage sustained when I wasn't driving it...trying to turn around on slippery ground and it slid into a trailer...the plastic end cap is going to be welded apparently, but the mounting lugs are missing so I am doubtful. Bumper is slightly twisted but repairable, but the damaged bodywork will be a pain to set right. I'm not paying for it, but I'm not too hopeful of it being paid for any time soon...
The old girl hooked up to the trailer that did the damage...can you guess what other kind of car I like too?
A towing job I did for a friend, moving his HOlden Torana drag car to get the Motec engine management wired in...it's got a VL Commodore Turbo engine in it with a much bigger turbo than the factory ever put there...
A close up of the Torana...
One of the times I took it to work before I took the gearbox out.
Just a shot of it sitting in the driveway.
Engine bay shot.
Other side.
In the garage waiting for its new bellhousing...
A pic of the interior with the engine cover removed.
The crappy dash arrangement, plywood painted black with a crappy tape deck stuck in it. Slated for removal quite soon...
I want a tachometer in there!
This is the hole in the floor for the 4 speed shifter, the 5 speed should come up in the same place. Check out the crazy gear lever, modified to bring the shifter out in front of the seats!
I am going to do better than this for the 5 speed!!!
Bit of interior work required, interior light missing, dash cover warped.
The 4 speed that came out. This is a Borg Warner 0503 "single rail" 4 speed from a 1980s Ford Falcon.
The 5 speed that is going in, a Borg Warner T5 from a post-1988 Falcon with the OHC engine, hence the bellhousing trouble.
The bellhousing I need is from a 1986-88 Falcon XF Series 2 S-Pack, the only ones with this gearbox/engine combination. At least it is on its way down now...
I have priced up the headlight upgrade I want to do, and it will cost somewhere north of $200 all up, which includes replacement H4 headlights to get rid of the sealed beams, plus heavy duty fused relays with direct wiring from the battery, heavy guage wire, and some decent bulbs. In fact it will probably cost $250...
Add another $100 or so for the wiring, plugs and fuses to set up the electric winch on the crane, and probably another $100 to purchase and wire up a swivelling worklight on the loading board. Don't want cheap crap, it's gonna be Narva or Hella or something like that. And it's getting the extra safety of individual relays and fuses for each light, so if a fuse blows all the lights don't go out...
