turbo transit time
Re: turbo transit time
Postby redeemer » Thu Oct 22, 2009 4:24 pm
Then let us know how you get on with the welding. Becase I didnt knew mig could do the job, but have bought welding rods adaptet for cast iron, but after a month using it it cracked again, on the side of the weld. I even warmed it up before welding , and even after welding . and imersed it in sand too cool slowly.
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby nokites » Thu Oct 22, 2009 6:28 pm
Problems you will encounter are the compression ratio will be to high. The turbo motor runs @18.3:1.
The nat asp runs @20.8:1 which could result in DET/game over
OLD CHINESE PROVERB
Man who works for nothing and women who f****s for nothing ---------ALLWAYS GOT PLENTY TO DO
nokites
Postby MinorMatt » Thu Oct 22, 2009 6:55 pm
I have a turbo head on mine, which drops the CR a bit (how much I am not sure because the turbos have different pistons too!)
Postby nokites » Thu Oct 22, 2009 7:12 pm
Yes its in the piston crowns
OLD CHINESE PROVERB
nokites
Postby redeemer » Thu Oct 22, 2009 7:51 pm
Mine is an 89 di, at least the head!
Its been a year since turboed, and still starts first time and running smooth. 8) fingers crossed!
I have always kept it to the max with the oil level, or even higher, so the splashes by the crank would cool off a little the pistons.
redeemer
Postby danSankey » Fri Oct 23, 2009 2:16 am
well the turbo we used is off of an RS turbo and my reasoning was yeah the RST revs higher but the DI has a bigger displacement so it should work but now i can see why diesels use really small exhaust housings, the T3 works really good and its got loads more power buti think if i can get a T3 compressor on a smaller exhaust turbine it'll boost it up a load
danSankey
Postby mrepson » Sun Nov 01, 2009 6:40 pm
keep the updates coming,and get some photos up of your mk5 recovery project. 8)
mrepson
Postby Finn_Timo » Sun Jan 17, 2010 6:47 pm
Is there any progress in this? It would be interesting to know, how did this actually work...
Ford Transit MK8 LWB '15 with 125HP
Frozen White
I have owned more than 70 units of Transit MK6/7/8, now 1st MK8
Finn_Timo
Postby reaper » Mon Jan 18, 2010 2:42 pm
keeping an eye on this myself some better pics would be good
reaper
