Durrants MK1 1973 Camper
Re: Durrants MK1 1973 Camper
Postby jc_durrant » Tue Jan 05, 2010 8:07 pm
jerry2 wrote:How much did you pay?
£300 for the camper
£180 to transport her back
£120 for the weller wheels.
£80 a day for welding (mates rate for 8 hrs! :mrgreen: ), £10 for the workshop rent when I use it so far 7 days done so £600 ish!
Probably spent another £250 on replacement panels, engine parts and sheet metal etc.. so far anyway :lol: :lol:
By the time its painted finished and on the road I reckon £2 - 2500 total cost. :roll: but at least it will have no rot and be mint well as close as can be
NOTHING IS IMPOSSIBLE! I JUST HAVEN'T DONE IT YET!
jc_durrant
Postby jc_durrant » Tue Jan 05, 2010 8:09 pm
dazzlebrush wrote:Hi your transit is as bad as mine i had to weld secondhand chassis legs and front crossmember in(ill put some pics on later) and had to remove engine and box so i could get weldingtourch in(took me weeks to do it) my steps were 90% fiberglass had to make new ones from scratch i used thicker gage sheet steel should last good few years.Ive got passengerside done im on with driverside but weather is holding me up as im working outside. I still body work to do door bottoms are well shot but ive got a door skin off a mk1 mini (mk1s have a square corner on them) and look like it might work as a repair panel.The floor had been welded up before and looks like a patchquilt but it will have do for now.Mine was a CI camper but when we went to push it(clutch stuck) out of its resting place the back corner gave way and when got it home found all wood framing to be rotten so now its a chassis cab/pickup any way good luck with the build
cool man keep me updated! watch ebay I have seen a few back bodys sell on their for only £150 recently
jc_durrant
Postby jc_durrant » Tue Jan 05, 2010 8:12 pm
MIXA wrote:Nice work looks like you have plenty to do,but if you can doit that well and have the time it will be well worth it keep up the thread lots of pics nice to see how someone else tackles diferent jobs , wish i had a garage like that would be out playing all the while
ask around mate I met this guy in the pub that mentioned he had one and offered him a tenner a day when welding it up if I could use his workshop you never know! or check local farms they always have unused outbuildings with power that they will let for cash
good luck :D
jc_durrant
Postby jc_durrant » Tue Jul 13, 2010 5:56 pm
Hi All,
You would not believe it but yes she is now fully legal and mot'd after 7 months of welding, painting and woodwork!!
I took her for her first run down to shepton mallet nass festival at the weekend but she overheated on the way down after 100 miles, I called recovery and they said she was fine so carried on and made it there ok with a bit of a mis fire occassionally.
Could not find any reason for the overheating, she had new thermostat with hole drilled in it, no blockages and water pump has no play?
My temp gauge has never worked though so bought a new aux Temp gauge from halfords with electronic sender just so i could keep an eye on her.
On the way back it became apparent he was wrong as she would not get over 30mph for 70 miles and then blew both heads by havant.
Hey Ho just changed the head gaskets and will set her up again, re time and hopefully will be ok.
James
jc_durrant
Postby jc_durrant » Tue Jul 13, 2010 7:19 pm
Some pics of the rear body and chassis work.
jc_durrant
Postby jc_durrant » Tue Jul 13, 2010 7:21 pm
some pics of the cab work, will update shortly when i upload the rest of the pics.
jc_durrant
Postby jc_durrant » Tue Jul 13, 2010 7:34 pm
every single bit has been welded seam sealed then i wire brushed, red oxided all the metal, stone chipped under the arches and painted all other metal with chassis black.
In the back I ripped out all rotten wood, treated and replaced all batoning where needed, re insulated the roof and walls before replacing hardboard and fitting 4 led 3 watt halogens in the roof panel.
jc_durrant
Postby jerry2 » Sat Jul 31, 2010 9:47 pm
Well done on the mot.
You must feel proud of yourself .
What insulation did you use on the rear as I've ripped mine out to sort out a load of leaks.
jerry2
Postby madmark » Sun Aug 01, 2010 12:19 am
wow this is comeing along so well 8) 8)
