My MK7 MWB med roof GLX
Re: My MK7 MWB med roof GLX
Postby Mike » Tue Mar 16, 2010 8:04 am
Guy88 wrote:Its fine, the box hardly moves at all, had it in tango like this and gurj had it in his blue on with 4 subs in and we all know how that sounded :wink: :wink:
I can't help feeling that it'll sound so much better and produce so much more bass with a bit or reinforcing. Also (it may be the pics) but it looks like you have two ported and two sealed boxes? :?
Mike
Wind up merchant!
Postby Guy88 » Tue Mar 16, 2010 8:23 am
i have :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby GRAVE DIGGER » Tue Mar 16, 2010 11:27 am
looking good , what amps are you going to using for the subs ??
GRAVE DIGGER
Postby Mike » Tue Mar 16, 2010 2:00 pm
Guy88 wrote:i have :wink:
I have to say that you're certainly challenging conventional thinking with that install.
Mike
Wind up merchant!
Postby Guy88 » Tue Mar 16, 2010 7:04 pm
GRAVE DIGGER wrote:looking good , what amps are you going to using for the subs ??
Got 4 hifonics 1000 rms to use and a JBL GTO fo the door speakers
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Gurj51ngh » Tue Mar 16, 2010 10:56 pm
Mike Spence wrote:That looks like 18mm mdf? It'll flop around like a prick in a bucket with those subs.
Not when its been made by me :wink:
Once the back of the box is on Mike there is not 1% flex. I agree you can add some supports internally like triangle braces but when I tested it and had it in my van for over a year it was fine.
The top two subs are ported can not remember the size of the box or port but if I remember right it was set to produce seriously low frequency's which only very few sub's can produce properly around 20hz I remember right
The reason I did not port the bottom box was the top two were a test to see how they went and boi they went well, But on some tracks which have very tight bass the sealed ones sounded better there was more of a hit from the bass rather then a shake that you get from the ported ones. So this was why I decided to leave the bottom box sealed so you can have best of both and it seemed to work really well. It was a test which went in the right direction.
It all depends on how mad you are what sort of music you listen to how much you have to spend where is it going in before you can make up your mind.
I heard 6 x 8" Kicker subs the other day in the back of a Focus, they may be 8" but they aint blooody cheap and boi are they powerful 450Rms each, the bass is so tight from them in a sealed box that when you sit in the drivers seat it actually moves your head for you moves your head :lol:
I think I may get two to use as some serious Mid bass :lol:
Gurj51ngh
Forums Loudest Van!
Postby Mike » Tue Mar 16, 2010 11:57 pm
Gurj51ngh wrote:Not when its been made by me :wink:
I'll reserve judgement until I hear it.
As for the 8" mid bass, some people say it's the only way to get proper mid bass. If you can get them in the doors and some 4" mids in the A pillars then it will certainly kick.
Mike
Wind up merchant!
Postby Guy88 » Wed Mar 17, 2010 8:29 am
all i can say is it sounded sh*t hot with 2 subs in mine and sounded even better with 4 in gurj's van :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sun Mar 21, 2010 7:14 pm
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby madmark » Sun Mar 21, 2010 7:18 pm
:shock: strange place for the night heater :shock: :shock:
Postby Altransit » Sun Mar 21, 2010 7:27 pm
madmark wrote::shock: strange place for the night heater :shock: :shock:
Is that what it is :shock:
I thought it was the exhaust for the sound system :oops: :? :roll: :lol: :lol: :lol:
Postby ake » Sun Mar 21, 2010 8:17 pm
A couple of cable ties and clips wouldn't go amiss :wink:
Postby Guy88 » Sun Mar 21, 2010 10:53 pm
ake wrote:A couple of cable ties and clips wouldn't go amiss :wink:
its all got to come out and have new OFC cables fitted, replacment RCA leads etc, dash is a bit tight on these thou :lol: :lol:
@ mark
its the only place it can go and not be in the way, if i put it at the front and it goes t*ts up i gotta pull all the sub box etc out to do anythin to it, where it is now its out of the way and wont be seen when its boxed in :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Mike » Sun Mar 21, 2010 11:05 pm
Guy88 wrote:its all got to come out and have new OFC cables fitted, replacment RCA leads etc, dash is a bit tight on these thou :lol: :lol:
Pah, just rip it apart.
Mike
Wind up merchant!
Postby madmark » Mon Mar 22, 2010 2:04 am
:shock: :shock: :shock: :shock: :shock: :shock:
