mk5 baby wrote:mk5 baby wrote:Hi there
another update
First attempt of overall
First removed wires from light connected to tow bar how unprofessional no wonder got problems
Second removed the tow bar that was just attached to bumper giving her a fail point on her MOT
well tried to said no to the spanner trick so it got a oxy burner on it hadid not stand a chance
Then found a source of wiring problems I'm still on with including a old dodgy alarm system that was ready to set me van alight arrghhdam wires
After that gave up with it had a fag come back another day.
Report to continue
Mk5 Baby
Report Continued my word oh sh*t
Where do I start firstly pics will follow shortly
Finally on to main bits
Passenger Side
Wheel bearing = totally shot
Brake Disc & Pads = Pads coming away from plate
Brake Hose = totally shot
Drivers side
Suspension Leg = other leaking
Wheel Bearing = totally shot more fragments then bearing![]()
Brake Disc & Pads =totally shot disc seriously damaged and pieces broken & pads coming away from plate
Brake Hose = totally Shot
General Service
Oil
Oil Filter
Fuel Filter
Other Parts
Two complete new front brake pipes
Other Parts to be done
Handbrake cable complete
Pair of rear brake pipes new complete front to back
Rear Shoes
Rear Drums
Diff Oil
Gearbox oil
Timing Belt
Drop old prop PTO,Compressor & Tanks
Plate rear Cross member
Rear quarter panel replace new x2
Rear Arches x2 replace new
Dodgy Wiring![]()
And some say about there MOT Failures on hereshould take a look at this one
MK5 Baby
transit mark wrote:Interesting read, looks a good project. Ill keep checking back.
Mark
redcube wrote:I hate to have drove your van with those breaks i thought mine where bad but yours is worse hope you get it a sorted
gonzothejaffa wrote:its gettin there pal i was going to ask about insulating to keep noise down an heat in
