T280 52 reg 2.2 st also mk6 to mk7 conversion project
Re: T280 52 reg 2.2 st also mk6 to mk7 conversion project
Postby cossie7 » Wed Dec 01, 2010 7:38 pm
Also just to let you all know I've already got Vantuner geared up for the mapping he says as he's never done one in person he's unsure exactly what it will make but looking at the mapping graphs 30+ extra should easily be achievable!! I've already done the decat etc prob fit cold air feed and filter and keep fingers tightly crossed for the 200ps mark.....
ID RATHER PUSH A TRANSIT THAN DRIVE A SPRINTER!!!
cossie7
Postby cossie7 » Wed Dec 01, 2010 8:46 pm
cossie7
Postby cossie7 » Wed Dec 01, 2010 8:47 pm
Well here's the van at the mo, just thought I'd show it before it's touched :)
cossie7
Postby winterheating » Wed Dec 01, 2010 9:14 pm
any chance of a closer pic of the pistons, they look a different shape to tdci and tddi transit ones. the 2.2 mondeo injectors do have a different type nozzle to all the mondeo and transit 2.0, 2.4 tdcis.
Also the 2.2 155ps mondeo injectors are cheapest from ford, you can get a full set of refurbs for £600. :shock:
Do you think you could measure the inlet and exhaust valves aswell?
Since i havn't split my engine yet as it seams ok.
Ive measured everything else on the engine and far as i can see is identical to the 2.0 just the different crank and conrods to get the 2.2.
winterheating
Postby cossie7 » Wed Dec 01, 2010 9:33 pm
Ok I'll measure the bits tomorrow when I pick them up and let u know
cossie7
Postby winterheating » Wed Dec 01, 2010 11:25 pm
winterheating wrote:
cossie7 wrote:No mate I don't think so but I'll find out soon enough haha
Thanks for the link for the box
Did you manage to find the measurements for the shafts? How much to remove etc?
yes i remember i wrote them on my wall so couldnt loose them, but theres a bit of stuff piled up on the wall :lol: :lol:
i found that wall :lol:
winterheating
Postby winterheating » Wed Dec 01, 2010 11:30 pm
Need to join them back in the middle at the non hardend parts :wink:
And offside needs the mondeo shaft on the inner side to allow it to fit the inner shaft with bearing on. :wink:
winterheating
Postby stu0500 » Thu Dec 02, 2010 5:46 pm
cossie7 wrote:Image
Now thats propper snow! Been in Durham today was class 20" of snow!
2012 vivaro 2.0 CDTI 140 bhp sortimo racking elec pack
2016 Transit custom Limited 155 ordered (with toys)
2013 Audi S4 B8.5 pearl black
2015 seat Leon FR 184 TDI Pearl black
stu0500
Postby cossie7 » Thu Dec 02, 2010 8:02 pm
That's not that bad mate you should of seen it the other day!! Bet there was 2 foot on top of my car!!
Also due to work today I havnt had a chance to pick engine up but will be doing it tomorrow afternoon so I'll get the measurements then and get some pics
cossie7
Postby sco77y transit » Fri Dec 03, 2010 12:39 am
cossie7 wrote:Just had the phone call from my local rebore shop and everything is mint!! So cranks been polished, bores honed, head pressure tested, tickled and valves reground, pistons and rods cleaned and checked.
So I'll get all the bits picked up tomorrow and get cracked on!!!
if thats all bits you have mate you need a lot more i tell you what i have used if you use less then your cutin corners dont no bout you but i like things mint right iner wings ,rain scuttle ,screen and rain scuttle plastics,wings, bumper, lights, front pannel,light pannels,bumper suport,tow hook, ends off chassis legs and you need to cut mk6 down as longer and mk7 are straight screen wash bottle ,water bottle the bracket for under bonnet fuse box but still need mk6 one as need to cut mk6 and stick it to mk7 bracket rads are different but i have left mk6 on have to make bits of tube to make top rad lugs go in place head lights plugs go in and work but have to sort indicator wires hope that helps mate :
sco77y transit
Postby cossie7 » Fri Dec 03, 2010 9:29 am
Cheers mate but looking at you list I think the only bits I don't have are the tow hook, screen, fuse box and washer bottle??
cossie7
Postby cossie7 » Fri Dec 03, 2010 7:45 pm
Well still couldn't get to rebore shop due to weather so if it's not open tomorrow it looks like a job for Monday lol
cossie7
Postby sco77y transit » Sat Dec 04, 2010 3:45 am
cossie7 wrote:Cheers mate but looking at you list I think the only bits I don't have are the tow hook, screen, fuse box and washer bottle??
screen same mate just plastics up side and scuttle plastics you only need fusebox bracket the 2 bits i take some photos of how i done it if you need to see cheers
sco77y transit
Postby cossie7 » Sat Dec 04, 2010 11:57 am
If you could mate that would be great, I've got the a pillar plastics and scuttle plastic. I started a couple of threads on here to find out exactly what I need but no one seemed to know or want to tell haha
cossie7
Postby cossie7 » Mon Dec 06, 2010 6:12 pm
Well picked all the engine bits up today and it turns out the block is U/S as the small pitting it one of the bores has not come out so looks like I'll be removing the engine from the van first and stripping it to use that block but never mind the head pistons rods and crank are mint. I'll get the measurements tomorrow of the bits wanted
cossie7
